The numbers probably had to do with individual bytes....
Regardless, Jeff's data sheet says the number is unlimited now though, just like SRAM.
More seriously, one does have to pay a bit of attention to part numbers. I have just found an FM1808 datasheet dated one month after the FM18L08 datasheet attached above which says that the non-L part still has 10^12 read/write cycles endurance. So I guess they were manufacturing both at the same time.
