It is currently Sun Nov 24, 2024 12:43 pm
PostPosted: Sat Oct 24, 2020 9:41 am
Just wanted to preview a Flash + EEPROM programmer shield PCB design and look for feedback/suggestions. I can't really afford a commercial device programmer so this seems like a relatively inexpensive way to be able to program the bargain priced 32-pin SST39SF series Flash ROMs as well as 28-pin 28C256 EEPROMs. After all, everyone has a $5 Arduino clone, right (grin)? Note: I still need to update the wiring diagram to reflect the flash/eeprom jumper wiring.
Stay safe. Cheerful regards, Mike, K8LH
PostPosted: Sat Oct 24, 2020 11:57 am
Very good idea! I think I'm right in saying that some Arduinos are 5V and some 3.3V, so that might be important.
PostPosted: Tue Oct 27, 2020 5:31 pm
Yes, that's important. This 'shield' is meant to plug into a 5 volt Arduino Uno R3 or similar clone.
I updated the wiring diagram and ordered boards with a flat black solder mask. I chose the economy shipping option and should have them by the end of November (cost around $1.82 per board).
Stay safe. Cheerful regards...
PostPosted: Tue Oct 27, 2020 5:33 pm
Oh, if that's a ZIF socket, beware that they often have weird pins and need bigger holes. (This advice coming too late, of course!)
PostPosted: Tue Oct 27, 2020 5:55 pm
I think I'm ok, Ed. I used 0.0354" diameter holes and the ZIF sockets with the flat wide pins seem to press fit (lightly) into that quite well.
PostPosted: Tue Oct 27, 2020 5:59 pm
Phew!
PostPosted: Fri Dec 04, 2020 5:19 pm
The PCBs turned out pretty nice and I've been workin' on software...
Stay safe, happy Holidays. Cheerful regards, Mike.
cron
