Hi Everyone,
Thanks for all the replies to the idea of the 65T2. Sorry it's taken me so long to reply in turn. I looked at the thread the morning (UK time) after I'd posted it; didn't seem to see any replies at the time and it's taken me a little while to get back to answering. And there's far more at the moment than I can hope to address (with zero page or not
A bit about my background: I have written a few posts in 6502.org; namely my initial attempt at writing uxForth (Unexpanded) Forth for the VIC-20 and a prior post on a hi-res game of life sim for the unexpanded VIC-20.
I am certainly not a 6502 guru, though I do have an interest in the CPU and computers. I have a number of actual 6502 computers: an Acorn Atom (I wrote AFAIK the first Macintosh Emulator for it in 1998); An Apple ][; and Apple //c; an Oric-1 and Commodore 64. I have a BBC 32Kb and B+ 128Kb (not a BBC Master).
I have an MPhil in computer architecture from Manchester Uni with the Amulet Research Group headed by Steve Furber (over the same period in 1996-1998). In addition I developed the FIGnition DIY, AVR based Forth computer about 9.5 years ago (I sold about 1000 of them). Amulet worked on asynchronous ARM processors.
I apologise if I have missed out important quotes.
cjs wrote:
(perhaps, moving up to "lower transistor/resource budget than the 6800") might allow for significant architecture improvement worthy of the cost.
Quite possibly. 65T2 predates the OP by a number of years and I just took the subject at face value here. 65T2 is me imagining how the Chuck Peddle team might have designed the 6502 if they'd had another 20 years of knowledge of computer architecture developments. So, to a large degree, the other constraints remain - particularly if they wanted to sell it for $45 in 1976.
But I'd like to start with
The 6800 supposedly has zero-paged addressing
The 6800 and 6502 are my primary... I don't think you're right here. To be probably overly brief
Being overly brief is the real problem with my paragraph. I didn't mean to claim too much, and some of it ought to be expressed as a hypothesis. It's certainly true that the early 8-bit MPUs tried to gain credence by relating their processors to minicomputer designs. For example, the 6800 was marketed as being similar to the pdp-11 (presumably because it had multiple addressing modes).
In my analysis, the 6800's architecture is mostly similar to minicomputer architectures such as the pdp-8 or HP2100, which themselves were descended from the TX-0, but also designs like the SSEM (Manchester Baby) were similar.
So, although one can categorise processors as being either single word instruction CPUs or multiple word instruction CPUs; I wouldn't normally class them like that, because e.g. one could compress a single-cell instruction set into a set of multi-cell instructions, but I would think of that as the same architecture, but with a different encoding.
But it is true that there has been a corresponding family of multi-cell computers, for example, the IBM 1401 which used 6-bit character based instructions.
As a whole, though most accumulator CPUs had a wide instruction format (e.g. KDF-9), because I guess it made decoding easy and because large mainframes could afford wide busses (wires were cheaper than components and the parallelism would offset the slow speed of the electronics).
With early 8-bit CPUs there was a major constraint on the number of pins, so that even accumulator based designs would be optimised by having multi-cell instructions, and page 0 optimised the limited bandwidth.
Hence, I think of the design of 6800 to be more related to accumulator based wide instruction set computers than e.g. the pdp-11 or IBM 360 or 1401. In which case the zero-page architecturally does relate to zero page or direct addressing on those kinds of machines.
In addition, it would make sense for the designers to take that approach, because the early MPUs weren't designed by people with experience in computer architecture (see oral history of 4004 and 8008), but people with experience in chip layouts, rubylith and the then pioneering MOS fabrication techniques.
In addition, most of the popular computer languages in the development time period for the 6800, 6502, 8080 and the other also-rans; were languages that were oriented around global variables, such as Fortran and BASIC (about 10 years old when the 6800 was released). In addition, the early 8-bit CPUs were expected to be used in embedded applications rather than fully realised computers.
So, I think I stand by the zero-page observation, even though my explanation was poor, but I do so, also because it's helpful in contrasting it with what might be done if one considers the principle of locality.
Modern CPUs are stack oriented, because the principle of locality means that most of the variable accesses in a given function will be a small subset of the complete address space. Thus, if we have n-functions each of which access on average m-variables, where m is a small number, then what we want is to be able to efficiently access n*m variables and if k and j are two of those functions with local variables a and b, we want to be able to alias variable k[a] in j[b] (e.g. by passing their addresses).
Now, we can employ tricks to achieve this with a CPU like the 6502, but that's not the same as saying the 6502 is designed to support those features, which is what the OP is about.
So, ultimately, observations on zero-page addressing are the means I use to be able to critique it in a 6502 alternative designed for 'C'. And I need to focus on that, because zero-page is one of the big cultural selling points of the 6502, so if I want to replace it, I need to have a good reason for doing so - it would be controversial.
Any modification of the 6502 to accommodate 'C' compilers has to do something equivalent, because you have to make the best use of the instruction bandwidth available: you can either bolt more onto the 6502 design (decreasing it's RISC-ish characteristics) or you can remove things you think aren't essential to make room for more efficient design decisions (from a compiler viewpoint).
And that's what I did: I removed all the zero page addressing modes to provide space for direct and indirect frame-pointer addressing modes. Then I tried to make the instruction set more orthogonal which would help compiler targetting.
PS. The 9-th Stack pointer bit is in the Flags register, though on reflection I don't think it should be restored if S is PULled.
Lunch is over, I'll have to add a bit more later. Thanks for reading this.
