I assume you mean the data generator in fill_for_quadratic_qsort_hoare()? ...
Indeed using randomness for the pivot selection makes almost impossible to intentionally design a bad sequence. But ordinary random data may be bad as well. So IMHO it is not good to rely on RNG. You know the sequence `qs_slow' killed gcc std::qsort - it means that it is risky to use it, use std::sort instead which guarantees N*Log(N) behaviors for any data.
I agree with you that switching to heapsort seems a bit too complicated. We also know that shellsort for numbers is noticeably faster than heapsort on modern cached hardware. However pivot manipulations do not guarantee from a pattern which can kill sorting. IMHO my 6502 quicksort guarantees N*Log(N) speed for every case.
It would be interesting to check your quicksorts and especially their 6502 implementations.
Just briefly on sorting... One thing to check is the number of comparisons needed - and what it is we're comparing. I found recently that a shellsort was faster than quicksort for sorting strings because for that particular data set I was working with (in my '816 BCPL system), the string compare was relatively slow, so it's always going to be hard to pick a "best" algorithm for everything. I don't think there is a "one size fits all" here.
Excuse me but it seems rather impossible. A quicksort is generally always faster than a shellsort. Because it just does less comparisons and exchanges. Maybe your quicksort implementation was not just optimized enough while your shellsort is optimized very well?
dmsc wrote:
The order of recursion does not change the speed, as the work done is the same.
The assembly code without recursion is slightly faster but I have found out that elimination of recursion is a wrong idea. It is because the recursion allows us to check the situations when a bad sequence is processed. So I removed the tail call optimization from my code.
dmsc wrote:
Porting FastBasic to other 6502 computers should not be hard - it is open source and I certainly would accept contributions!
Porting to other processors would be a lot of work, as you would need to rewrite all the interpreter and the parser machine, but at least the parser bytecode can be used as is.
It is an interesting idea to port it for the Commodore +4. However I have still had a bit deserted project of my own Basic compiler -
http://litwr2.atspace.eu/plus4/cbcwif.htmlIndeed it is not easy to make a port for a different processor but maybe the 6800's people will help?
dmsc wrote:
That line should be "LOOP UNTIL lvl = 0", as QBasic defines NOT as a binary operator (NOT A = 65535 - A), so you must always compare with 0. FastBasic is modeled on Atari BASIC, with the "C like" convention that uses the boolean as a type and AND/NOT/OR as boolean operators.
Thank you very much. It works now. It is a shame for me that I didn't check Basic's NOT real meaning.
dmsc wrote:
This is my working QBaic code, with timers to measure the speed:
' QuickSort - using 2-way partitioning
' 2-way partition is faster if there is not a lot of repeated elements
DEFINT A-Z
Thank you. It works. But it is almost impossible to compare speeds of algos for so different languages as assembly and Basic. IMHO my quicksort can't be realized on Basic. I can implement it on C using longjmp/setjmp but Basic doesn't have such functions.
What do you think about double pivots quicksort?
https://github.com/litwr2/research-of-s ... ick-dp.cpp IMHO it is one of the best, they set it the standard sort for Java. However it seems that it is possible to design a bad sequence for it too.
BTW this discussion has forced me to start a new small github project -
https://github.com/litwr2/6502-sorting It is interesting that the 1 MHz 6502 may sort the same 60000 bytes sequence during about 50 hours (!) with insertionsort, 60 seconds with shellsort, 40 seconds with quicksort and only 6 seconds with radixsort. It is also interesting that modern computers sort 8 GB sequence for about the same timings.
dmsc wrote:
The "trick" of selecting the pivot from the median of three random values does in fact reduce the probability of quadratic behavior - in fact it is so unlikely on big inputs that it is much more probable that your computer just breaks than the sorting time is more than double of the mean.
The reason QuickSort is avoided on uncontrolled inputs is that if you don't use a secure RNG, an attacker can give you a crafted input, and using a secure RNG can be tricky.
IMHO just use an absolutely safe quicksort like its hybrid form introsort.
Would you like to give me a link to any information that proves your point about the reduction of the probability of quadratic behavior with pivot selection methods? Thank you
