CF-Card / RTC BIOS - initial code working
- floobydust
Re: CF-Card / RTC BIOS - initial code working
I've done some additional testing on using the /SO line.
First, the /SO pin does in fact set the overflow flag, no issue there, and of course, the CLV instruction will clear it. So the current WDC chip works as it always has. All good news....
However, I've not been successful at using this for handshaking the data transfer from the CF-Card (in True IDE mode). The transfer loop never breaks... which means the IOCS16 line continues to remain active. My guess is the IOCS16 line does not reset unless the Status register is read (which shows the DRQ - data request bit) as part of the loop. I'll need to break out the logic analyzer again and do some additional testing on this one. In any case, if this turns out to be the case, then there's no benefit to using the IOCS16 line to trigger the /SO line... as reading the Status register appears as the only working form of handshaking for data transfer (outside of different design which uses DMA, which isn't happening for my hardware design).
I've updated the new BIOS and will post it once I get some additional testing done... so far, so good.... data transfer rates are in excess of 250KB per second and vary a bit between different size CF-Cards.
- floobydust
I've run basic tests using the update BIOS via the JUMP table calls.... which have changed slightly. I've also managed to streamline the code bit. I've decided to post it here along with the updated Monitor which also required some changes to support the new RTC code, etc. I've got some additional CF Cards on order which should arrive next week, so I'll do some additional testing on these as well. In the meantime, the code posted has been working reliably.
On a side note, I've noticed that the Maxim DS1511 runs on the fast side... gaining a second or more per day. Granted, the accuracy specified in the datasheet is +/- 1 minute per month. I just think it's fairly poor accuracy compared to most standard system boards these days.
- BigDumbDinosaur
±1 minute per month averages to ±2 seconds per day, which means your RTC is running within spec. Self-contained RTCs are not the most stable time sources, which is why it is best to use the RTC only to get an initial date and time, and thereafter use a binary software clock driven by a stable timebase that runs in the megahertz range. That's why I use the DUART's counter/timer to count jiffies. The drift on the 3.6864 MHz oscillator is small (I use 100ppm oscillators, which are the Walmart version), and timekeeping drift is about one fourth of what I was seeing with the DS1511.
Actually not. My company has built hundreds of servers since 1988 and I probably can count on both hands the number of motherboards whose RTCs kept good time, meaning within a few seconds per month. It's just the nature of the beast.
(A quick check suggests 1 second per day is about 12 ppm.)
- BigDumbDinosaur
Of course, a 100 ppm or 50 ppm rating for an oscillator is a worst-case number. Odds are pretty good most production parts will be better than that.
And here I was upset that my SBCs were 1s apart after a month!
My work laptop loses 4 minutes over a 2 day weekend.
- floobydust
Well, I know that the RTC chip is within specification.... but then again, I have four of my C02 Pocket SBC boards running which are much more accurate with the BIOS RTC code, which uses the 16-bit counter/timer of the SCC2691 with it's own crystal, hence my mention of the DS1511 accuracy. As Ed noted, 12ppm is about right... still, I have older PS/2 Servers that are still within 10 minutes or so, after more than 20 years of sitting around, go figure.
On the other side of this post, I'm fairly happy with the last BIOS update... the detection strategies for the RTC and IDE have worked out well and the supporting code for each device has been working properly as well. The entire BIOS is just a bit over 1.5KB and has a fair amount of function for it's size (I still have 252 bytes of contiguous BIOS space left). I think the hardware and software are now at an initial level where getting an existing OS (Flex or DOS/65) working are now possible.
- floobydust
Still making progress on this project... and am writing a utility for the RTC and CF Card. I have found that setting the Date/Time on the DS1511 is a bit odd. After loading the registers and enabling the transfer, the time is always about 2-3 seconds behind. This seems to imply that the RTC doesn't transfer the new settings and start counting right away. I've not found anything in the datasheet that would tend to explain this delay, but I don't see how it would a coding problem... the datasheet is pretty clear on setting the clock.
Has anyone else noticed this problem?
- BigDumbDinosaur
Last edited by BigDumbDinosaur on Sat Dec 19, 2020 3:55 pm, edited 1 time in total.
- floobydust
Here's the snippet of code that sets the RTC of the DS1511:
I load the registers first, then wait for the enter key to finish setting the TE bit, which should move the updated register over and start the RTC clock function.
RTC_TIME_SET
STZ RTC_CONTROL_B ;Clear TE bit for RTC Set
SED ;Set decimal mode
LDA RTC_LOAD+0 ;Get Century
STA RTC_CENTURY :Set Century
LDA RTC_LOAD+1 ;Get Year
STA RTC_YEAR ;Set Year
LDA RTC_LOAD+2 ;Get Month
STA RTC_MONTH ;Set Month
LDA RTC_LOAD+3 ;Get Date
STA RTC_DATE ;Set Date
LDA RTC_LOAD+4 ;Get Day
STA RTC_DAY ;Set Day
LDA RTC_LOAD+5 ;Get Hours
STA RTC_HOURS ;Set Hours
LDA RTC_LOAD+6 ;Get Minutes
STA RTC_MINUTES ;Set Minutes
LDA RTC_LOAD+7 ;Get Seconds
STA RTC_SECONDS ;Set Seconds
CLD ;Clear Decimal mode
RTC_TIME_SYNC
JSR M_RDCHAR ;Get character from user
CMP #$0D ;Check for C/R
BNE RTC_TIME_SYNC ;Loop until C/R entered
LDA #%10000000 ;Get TE Bit to enable update
STA RTC_CONTROL_B ;Set normal Transfer Mode
LDA #<RTC_CONFIRM ;Load Message address
LDY #>RTC_CONFIRM ;into A/Y regs
JSR M_PROMPTR ;Send message to console
RTC_END
JMP USER_INPUT ;Prompt User to return or continue
Silly question, why switch to decimal mode to do the register loads?
Doesn't setting the decimal flag only affect ADC and SBC ??
Yes, the D flag only influences ADC and SBC. You don't need it set to merely move BCD values around.
More importantly, it looks like you're loading the RTC registers with a time, then waiting for user input before resetting the TE flag. This results in the RTC's internal operations being inhibited for several seconds, probably, which I'm sure upsets some internal counters that are used to divide the 32kHz oscillator into seconds. I think you might find it works better if you keep the period where TE is set as short as possible, ie move the wait for user input to the very top of the code given above.
- floobydust
I agree on the SED/CLD comment... however, when I initially tried setting the RTC, it locked up the chip... so I added the SED/CLD and that fixed it. I never bothered to revisit this part of the code, but I will.
On the TE bit, at first I was flipping the bit immediately in the code without waiting for input.... but it still ends up being 2-3 seconds behind what the registers are set for.
According to the datasheet, the internal oscillator/counter continues to run and update the internal registers regardless of the TE bit setting. The TE bit should only be halting the updating of the accessible registers, but there seems to be an issue on transferring the updated registers... hence my post
- BigDumbDinosaur
Here's the snippet of code that sets the RTC of the DS1511...I load the registers first, then wait for the enter key to finish setting the TE bit, which should move the updated register over and start the RTC clock function.
04276 ;================================================================================
04277 ;
04278 ;putdtr: WRITE RTC DATE & TIME REGISTERS
04279 ;
04280 ; ————————————————————————————————————————————————————
04281 ; Preparatory Ops: .X: source address LSB
04282 ; .Y: source address MSB
04283 ;
04284 ; Source must contain 8 BCD values in
04285 ; the following order:
04286 ;
04287 ; Offset Content Range
04288 ; —-—-—-—-—-—-—-—-—-—-—-—-—-—-
04289 ; $00 seconds $00-$59
04290 ; $01 minutes $00-$59
04291 ; $02 hours $00-$23
04292 ; $03 day-of-week $01-$07
04293 ; $04 date $01-$31
04294 ; $05 month $01-$12
04295 ; $06 year LSB $00-$99
04296 ; $07 year MSB $00-$39
04297 ; —-—-—-—-—-—-—-—-—-—-—-—-—-—-
04298 ;
04299 ; Returned Values: .A: entry value
04300 ; .B: entry value
04301 ; .X: entry value
04302 ; .Y: entry value
04303 ;
04304 ; MPU Flags: NVmxDIZC
04305 ; ||||||||
04306 ; ++++++++———> entry values
04307 ;
04308 ; Example: ldx #<todbuf
04309 ; ldy #>todbuf
04310 ; jsr putdtr
04311 ; ————————————————————————————————————————————————————
04312 ;
04313 00D47D 08 putdtr php ;save MPU state
04314 longr
04315 00D47E C2 30 rep #%00110000
04316 00D480 0B phd
04317 00D481 5A phy
04318 00D482 DA phx
04319 00D483 48 pha
04320 00D484 A9 00 00 lda !#kerneldp ;set default...
04321 00D487 5B tcd ;direct page
04322 shortr
04323 00D488 E2 30 sep #%00110000
04324 00D48A 98 tya ;storage address MSB
04325 00D48B EB xba ;move to MSB of .C
04326 00D48C 8A txa ;storage address LSB
04327 longx ;16 bit index regs
04328 00D48D C2 10 rep #%00010000
04329 00D48F AA tax ;source index
04330 00D490 A9 80 lda #d11temsk
04331 00D492 1C 0F C3 trb io_rtc+wr_crb ;halt register updates
04332 00D495 A0 00 00 ldy !#0 ;register offset
04333 ;
04334 00D498 A9 00 .0000010 lda #0 ;dummy value
04335 00D49A C0 05 00 cpy !#wr_mon ;month register?
04336 00D49D D0 05 bne .0000020 ;no
04337 ;
04338 00D49F B9 00 C3 lda io_rtc,y ;get month & control
04339 00D4A2 29 E0 and #d11ecmsk ;discard old month value
04340 ;
04341 00D4A4 15 00 .0000020 ora mm_ram,x ;get new value
04342 00D4A6 99 00 C3 sta io_rtc,y ;write RTC
04343 00D4A9 C0 07 00 cpy !#wr_yrhi-wr_sect ;all registers written?
04344 00D4AC F0 90 beq getdtraa ;yes, done (below)
04345 ;
04346 00D4AE E8 inx ;next location
04347 00D4AF C8 iny ;next register
04348 00D4B0 80 E6 bra .0000010
04172 00D43E A9 80 getdtraa lda #d11temsk
04173 00D440 0C 0F C3 tsb io_rtc+wr_crb ;resume register updates
04174 longr
04175 00D443 C2 30 rep #%00110000
04176 00D445 68 pla ;restore MPU entry state
04177 00D446 FA plx
04178 00D447 7A ply
04179 00D448 2B pld
04180 00D449 28 plp
04181 00D44A 60 rtsx86? We ain't got no x86. We don't NEED no stinking x86!
Also, what's the point of waiting until the user strikes <CR> to set the TE bit?... If you wait to set TE your time will lag by however long you waited.
(Though, as others have pointed out, doing all the writes after pressing Enter will take so little extra time—a few hundred microseconds—that separating the two won't give you any extra accuracy.)
