It is currently Fri Sep 20, 2024 5:30 pm
PostPosted: Thu Oct 01, 2020 3:43 pm
Hi. I'm trying to get a simple routine to print the current time in the screen, using the W65C265SXB-like computer.
My code is:
.cpu "65816"
.xl
*= $1100
SEI
CLC
XCE
REP #$30
SEP #$20
LDX #$1130
LDA #$00
JSR $E057 ; This subroutine reads the time and stores it as ASCII where Xreg is pointed to ($1130 in this case)
JSR $E04E ; This subroutine reads a string stored where Xreg is pointed to and prints it to the console (COM3 in my case).
brk
Well... the results are either:
  • does nothing
  • freezes the board
What am I doing wroing? This must be something of the most basic stuff that I'm missing. This is the very same SBC where the SXB hacker and ehBasic runs flawessly, so it's my wrong doing for sure.
Thanks.
PostPosted: Thu Oct 01, 2020 5:28 pm
I'm certainly no expert on the SXB. But certainly the stack pointer needs to get initialized at some point. Was that already done before your code gets run?
PostPosted: Thu Oct 01, 2020 5:48 pm
Thanks. That's my code. Everything you think is missing or wrong, is missing or wrong.
PostPosted: Thu Oct 01, 2020 7:19 pm
tokafondo wrote:
That's my code.
Yes. But I'm imagining what you do in order to try the code. For example, perhaps the machine monitor program produces a prompt on the console, and you somehow respond to say, "run this." In that case the monitor would already have initialized S, and there's no need for you to do it again.
(You're not burning the code into an (E)EPROM, are you? If so, then maybe the monitor won't have had a chance to initialize S.)
Did you create your code by modifying an example borrowed from elsewhere? If so, does the UN-modified example work? Have you studied the SBX doc? (I haven't, and don't presently have time.)
BTW I notice your SEP instruction partially negates what the REP accomplished.
REP #$30  ;clears bit 5 and 4 of the P register
SEP #$20  ;sets   bit 5 of the P register
PostPosted: Thu Oct 01, 2020 9:17 pm
These utility routines must be called with JSL and not JSR.
The documentation does not say that read time preserves the registers so you should reload them before the call to put_str.
Andrew Jacobs
PostPosted: Thu Oct 01, 2020 9:36 pm
Thanks. I'm just being sure that I put the Acc and Registers in 16 bit mode, and then only the Acc in 8 bit mode.
I wrote the code by myself, and put that SEI, CLC, XCE instructions because it seems to me it's the standard way to initialize any code in the '816.
Thanks. Do that implies that Acc and Registrers should be both in 16 bit mode? Or can I JSL everywhere I'd need, no matter the data width?
I've searched for an opcode for that, and I can't find it. How do I reload the registers before calling put_str?
PostPosted: Thu Oct 01, 2020 9:41 pm
.cpu "65816"
.xl
*= $1100
SEI
CLC
XCE
REP #$10
SEP #$20
LDX #$1130
LDA #$00
JSL $E057 ; This subroutine reads the time and stores it as ASCII where Xreg is pointed to ($1130 in this case)
LDX #$1130
LDA #$00
JSL $E04E ; This subroutine reads a string stored where Xreg is pointed to and prints it to the console (COM3 in my case).
brk
Andrew Jacobs
PostPosted: Thu Oct 01, 2020 10:07 pm
BitWise wrote:
.cpu "65816"
.xl
*= $1100
SEI
CLC
XCE
REP #$10
SEP #$20
LDX #$1130
LDA #$00
LDX #$1130
LDA #$00
brk
Thanks. Oh! I see... it was a matter of rewriting the registers the following subroutine expected, because the previous one could have overwritten them, couldn't it?? Thanks, again.
PostPosted: Thu Oct 01, 2020 10:10 pm
There's a problem there. The accumulator is one of the main registers. There is one status bit, M, for the accumulator width, and one bit, X, for the index-register width. Most memory operations that do not involve a register will be done according the M bit, for example INC <addr>. But see below:
Thanks. Does that implies that Acc and Registrers should be both in 16 bit mode? Or can I JSL everywhere I'd need, no matter the data width?
M and X have to do with data-handling size, not address size. The "L" in "JSL" means the operand, which is an address, is three bytes. It doesn't care what the data size is.
PostPosted: Thu Oct 01, 2020 10:26 pm
Thanks for your help. I should be reading that "65816 programming" book from WDC instead of jumping into the pool while not being able to swim... 8) 8) 8)
It seems there is something also with SEND_CR ($e066) subroutine, because if I put it like this
jsl $00e066
jsl $00e066
LDX #$1130
LDA #$0000
JSL $00E04E ; This subroutine reads a string stored where Xreg is pointed to and prints it to the console (COM3 in my case).
jsl $00e066
jsl $00e066
brk
...to force blank line, it doesn't work at all. But If I remove them, the code works, by outputting the time running in the computer.
PostPosted: Thu Oct 01, 2020 11:08 pm
The Mensch monitor only outputs CR for a new line. Your terminal program needs to be configure for automatic new lines (i.e. it generates the line feed for you).
Andrew Jacobs
