JustClaire wrote:
Hello
I have been making an emulator for 6502 for the past week but i am stuck at an issue.
WARNING: this question is not entirely about 6502, but more about emulator design in general.
The CPU emulation code can currently run at ~70-80MHz on average, but i am having trouble controlling the frequency precisely. I want my code to work multiplatform but Afaik windows api does not allow for nanosecond precision timers unlike unix so i cannot set the emulator to run precisely at a few MHz.
It is kind of ironic that the issue is running code slower than its max speed.
What would be the preferred approach to control emulator frequency? I want to be able to at least run it at the max datasheet frequency of 14MHz if its possible
One thing to note is that not all Unixes/Linuxes/BSDs/etc. have nanosecond resolution and sometimes other means have to be employed. And even if you do have seemingly ns timing, you should always check the minimum interval possible - use the clock_getres(2) system call to see what's possible. also check the minimum duration of a system call - especially things like sleep(), nanosleep(), etc. you may well find that they are much longer than you're expecting.
One thing I did for my cycle-accurate PDP-8 emulator a while back was to bypass the kernel and use a hardware timer because the system I was running it on only had a resolution of 1µS and I needed something quicker - that was on a Raspberry Pi Zero and obviously isn't possibly on all platforms. So my strategy was:
- Read the hardware timer (A)
- execute my C code to Interpret the instruction
- Read the hardware timer again and use it to calculate the time left to the next clock tick (cycleTime - (current - A))
- Busy loop for this time, reading/comparing the hardware timer
That works remarkably well and I was able to check my cycle timing against a real PDP-8 and they matched.
Personally, cycle accurate is the way to go because (other than the fun with a PiTubeDirect - 65C02 @ 300Mhz) then if you want faster you might as well use a different CPU IMO ... (although there are scenarios like ...
that obscure bug that only happens once a day where speeding up the emulating might help debug it, etc. but then how did they do it on the old days...)
See my
Ruby 6502 and 65816 SBC projects here:
https://projects.drogon.net/ruby/
