It is currently Sun Sep 22, 2024 10:29 am
PostPosted: Fri Aug 21, 2020 6:04 am
The zoogies could also arise due to poor power/ground distribution....
Yep, which has the side-effect of interfering with good bypassing. Even at 1 MHz, dubious construction methods can give you grief.
PostPosted: Tue Sep 08, 2020 9:35 pm
Just wanted to give an update regarding my issues. It turns out my suspicions where indeed correct. They were all due to a faulty RAM IC. Something about the one I originally received just didn't function properly except at very very low clock speeds. I ordered 2 replacements and both functioned just as expected. Thanks everyone for your help debugging.
PostPosted: Wed Sep 09, 2020 2:03 am
Glad you're having some success now. One question, if I may. After successfully testing the new RAM's, did you then also re-test the original RAM to verify that the malfunction returns as expected?
Worth a try, if you haven't done it already. That's because once in a while you may encounter a case where the chip is actually OK but nearby wiring on the board is flaky. Maybe there's a bad solder joint or a tarnished IC socket or whatever -- stuff happens, as they say! :roll: Replacing the chip can disturb the flaky wiring and make the symptom disappear -- and of course that makes the wiring issue superficially appear to be a chip issue.
PostPosted: Wed Sep 09, 2020 3:52 am
From where are you obtaining your parts?
Just for grins, you should try what Jeff suggested to see if it really was a foobar part.
PostPosted: Wed Sep 09, 2020 4:46 am
That is exactly what I did. I wanted to make sure I wasn't crazy. I guess moral of this story is to have extra ICs on hand.
PostPosted: Wed Sep 09, 2020 5:57 am
and be careful where you get them from, and use appropriate static protection handling. I have virtually no idea how many millions of ICs our company might have bought for the products I've designed them into, and to my knowledge, we have never gotten a bad one from a legitimate distributor. eBay is probably not the right avenue to buy through. Get them from the major distributors like Mouser and Digi-Key. There are hundreds more American distributors (and we do use other ones besides these two as well), but Mouser and Digi-Key work well even for hobbyists, and have an unimaginable inventory.
PostPosted: Wed Sep 09, 2020 8:57 pm
I have to tell you I've been working with digital electronics for some 50 years and can count on one hand the number of defective parts I have gotten. New faulty chips these days are rarer than unicorns wandering the streets. On the other hand, purchasing parts from dubious sources can get you counterfeits...caveat emptor!
