Meet the 65F02 - a 65C02 at 100 MHz
Re: Meet the 65F02 - a 65C02 at 100 MHz
@cjs: Thank you for the details about usage of the extended memory in the Apple II. I guess I have only ever used my language card for UCSD Pascal, which may be a special case. To support switching back and forth between RAM and ROM, I guess my best bet, in view of the limited 64k block RAM I have in the FPGA, is a compromise: Upon startup, read in (and accelerate) the ROM; allow it to be overwritten and used as RAM once the language card gets enabled; and then revert to un-accelerated mode in that address space whenever the ROM gets switched back in.
For the more advanced Apple //e and //c, I am firmly with Ed: That's out of scope for me, just like the BBC Master. Too much hassle and an awkward solution; and the result would be less than convincing since I could only accelerate a fraction of the available host memory.
Besides technical reasons, personal preferences and nostalgia come into play too, to be honest. The Apple II plus was my first computer -- I still have it, and did my initial tests of the 65F02 on that very machine. And UCSD Pascal was dear to my heart as my first "real" programming language, so I would like to support it. But by the time the Apple //e came out, I had moved on to 68000 systems, so that generation of machines does not mean as much to me.
Supporting a much larger, off-chip RAM would be neat, but I don't think I can accommodate it in the 40-pin DIP footprint. Even if I find room for the chip, bringing out approx. 30 additional address/data/control lines from the FPGA seems impossible:
The design rules of the affordable PCB houses (like Aisler, OSH Park, and the various Chinese fabs) allow for one trace between BGA pads, or one via in the middle of a square of pads, for this 0.8mm pitch BGA. With the narrow PCB, one can essentially only bring out traces towards the short sides of the PCB, and those are pretty crowded already. There's limited room for more vias to other layers, since the decoupling caps block the bottom layer below the FPGA.
I'm attaching a view of the top and bottom layer (without the pours) to give a better idea. Blind vias seem like the only way to bring out significantly more traces, and none of the cheap PCB places support those.
Even the IIc's original 16K v255 ROM uses a few locations in the auxilliary address space (such as the "screen holes" in the frame buffers allocated to data storage for I/O devices), so if you don't support this the system probably won't even boot, and certainly some devices (such as the serial ports) won't work. But many of these are little used, or even not used at all after setup if you're not using some devices. With the later 32K ROMs there is code in the alternate ROM bank that is used in normal operation, but not a huge amount of it. I don't have a figure, but my guess would be that in these cases over 90% of ROM accesses are from the main bank, not the alternate bank.
If you commit to supporting the language card at all, you've committed to emulating memory management logic in the 65F02. And come to think of it, if you commit to supporting an Apple II with any cards beyond a single disk controller in slot 6 (or any other single card) you still have to commit to emulating memory management logic anyway, because the $C800-$CFFF space is bank switched between the ROM on each card. (PR#6 switches in the ROM on slot six before jumping to it.)
Especially if you're going to be doing this for any other systems, it seems worthwhile to develop a "mini-language" to describe such memory management logic, which would need to describe:
- Which ranges of the address space are banked, and what's backing each bank.
- How to deal with each bank: internal RAM only, external access only, write-through on free external bus cycles (if you want to implement that), and perhaps in the future some sort of LRU cache or something like that.
- Which addresses and what kind of access to them (read, write, two sequential writes, perhaps other patterns) change the bank currently in use in a given area of address space.
Even for just the Apple II language card it seems to me simpler to develop and debug a simple, general system like this than to try to special-case the whole thing, and once you have this it's easy to add support for a lot of other systems, too, including the IIc, which is not inherently more complex but just has a few more mappings.
The one thing this does not yet get you is support for systems like the C64 where external signals contribute to determining memory mapping. A simple way to handle that woudl be to have a few connections on the board to serve as inputs to the memory management logic; C64 users could then wire up the /GAME and /EXROM signals (provided by whatever's plugged into the cartridge port) to this and the memory management logic could examine the state of those as well as its internal state from past instructions executed to determine the current mapping for any address range.
Supporting a much larger, off-chip RAM would be neat, but I don't think I can accommodate it in the 40-pin DIP footprint. Even if I find room for the chip, bringing out approx. 30 additional address/data/control lines from the FPGA seems impossible....
This has already proven to be a sensitive area of the FPGA timing as I kept adding (simple) memory maps for more chess computers. On the other hand, if a generic solution is feasible which gets configured at startup (when the FPGA determines its host type), rather than having all the different supported decoders sitting side by side in the logic fabric, that may simplify the decoder somewhat. I'll give that some thought!
Note that in this model of 65F02 memory management the RAM and ROM at the $E000-$FFFF range actually are viewed as four mappings: read/write ROM, read ROM/write RAM, read RAM/write ROM ("read only RAM") and read RAM/write RAM. (The $D000-$DFFF bank will be the same, except with further mappings because there are two RAM banks.) Not supporting all of these will almost certainly break a lot of software (including, probably, UCSD Pascal) because it's common use the read ROM/write RAM mapping during setup so you can call ROM routines while loading the language card.
Supporting the two separate 4k blocks which can be mapped into the $Dxxx address space is a bit more of a headache: I have the extra 4k, since I never need internal RAM for the $Cxxx I/O area, but need to translate an internal address to a different one when the alternate block is accessed. That adds some complexity to a timing-critical path: Because the block RAM is physically distributed across the whole FPGA chip, getting addresses and data to and from the outer blocks incurs significant routing delays...
65f02 wrote:
Well, my "solution" for that particular problem is embarrassingly simple: I always map the complete $C000..$CFFF space as external, i.e. I let the 65F02 access the actual host I/O and the ROMs on the I/O cards.
I figure that that code is likely to contain some cycle-counted, timing critical sequences; and for most cards it deals with I/O operations where the throughput will be limited by the peripheral device anyway.
But that does bring up another problem, one that seems to me much harder than the memory mapping one: how do you run Apple DOS (or anything that uses the Apple II drive)? The code there is running from regular RAM (and not even from a fixed location), is extremely timing criticial, and you can't just slow down only the I/O accesses because other non-IO instructions that are being executed are also part of the timing loop. At first glance, this seems to be the biggest problem with your CPU working in an Apple, and may well affect other systems, too.
Noted, thanks. I have re-read the language card documentation (after a very long time...) prompted by your posts. Supporting the different read/write access combinations should be straightforward, but of course the logic has to be aware of them. I think I will keep it simple -- as soon as a "write to RAM" mode has ever been enabled, I would direct all future ROM read accesses to the actual external ROM, since I can't be sure I still have an intact copy in the on-board ROM.
Indeed! You're using a -3 FPGA, I notice, which is faster than the -2 on the boards I'm familiar with, so that will help. Have you needed to do anything to the CPU to speed things up, or to the memory system? I don't suppose you've gone so far as to place parts of the design?
cjs wrote:
how do you run Apple DOS (or anything that uses the Apple II drive)? The code there is running from regular RAM (and not even from a fixed location), is extremely timing criticial, and you can't just slow down only the I/O accesses because other non-IO instructions that are being executed are also part of the timing loop. At first glance, this seems to be the biggest problem with your CPU working in an Apple, ...
But indeed, this is awkward. Having the 65F02 settings depend on software details of the host system, rather than just its hardware, is a kludge. But unavoidable for systems like the Apple, I'm afraid.
Even for the Apple there will be plenty of software where acceleration does not work (e.g. because the software brings its own disk routines, for copy protection or other reasons), or where it does not make sense (e.g. for action games which should run at their intended speed). I will have to implement a way to switch the acceleration on an off -- in fact it should probably default to "off" upon power-on to retain compatibility. I'll go looking for an unused address which I could grab as an I/O address for a software switch, I think.
... and may well affect other systems, too.
The 100 MHz clock rate is marginal though: Trivial changes in some non-critical part of the VHDL can throw the place/route optimizer off course sometimes. I have tried to set a few placement constraints, but found them to help only for one fixed version of the design, and become counter-productive when something changes. I might be doing it wrong, or more likely, might just be trying trying to push the optimization a bit too far. The sensible thing would be to step the clock rate back by a few MHz, which would be barely noticeable in practice -- but for now I have managed to keep fiddling with the design to maintain the magical "100"...
I have been wondering whether another level of pipelining (pre-fetching) in the core would make sense. The path for fetching data from RAM, using them in the core to determine the next address, and sending the address back to the RAM is one of the bottlenecks. But I was (a) too lazy, (b) too concerned to break something, and (c) interested in keeping the original timing when operating non-accelerated from external memory; so I have not really looked into modifying the core to do pre-fetching.
65f02 wrote:
For a given version of DOS, the critical RWTS (read/write track/sector) routine and the motor-stepping routine should be in a fixed location to my knowledge.
But merely providing 48K of memory won't fix the issue with "slave" diskettes formatted on systems with less than 48K of RAM because those load DOS in the location it existed on the system that did the format. (One must run a separate MASTER CREATE program to create diskettes that relocate their DOS on boot.)
That said, that's probably less of an issue to most users than all the other software that has its own RWTS routines, so just knowing that this issue exists, you can handle it the same way as those others. (Probably by telling the user, "This kind of stuff won't work." :-P)
So I can define the memory areas where code has to be executed from external ROM to preserve the timing.
We found the Commodore PET 8032 to behave much more "orderly" than the Apple II...
Maybe, just maybe, it would be workable if the machine drops to normal speed whenever it sees an access to a disk i/o address (I guess there are only a few of those) and then stays in normal speed for some extended period, maybe as much as the time it takes a disk to rotate. Twice. And of course resetting that counter on every such access.
Uncle Warthog
Ah, interesting, thanks. Always good to hear about prior art. (I think I recall that one of the Apple II accelerators sat in the 6502 socket, but another one sat in an extension card. I could have that wrong.)
Well I've just had a thought.
Perhaps we can take advantage of the maladroitness in the 6502 that causes it to use an extra cycle when branches cross page boundaries. Because of this, coders of time-criticial routines often ensure that they don't cross a page boundary (because this is much easier than making sure that the page boundary crossing doesn't cause cause any harm), and this is exactly what DOS does with the RWTS routines.
So one heuristic that might work reasonably often is, whenever an access to a disk I/O address is discovered, immediately mark that whole (256-byte) page as code to be run at standard speed. (This is not quite the same as just marking it external; even accesses to memory outside that page, when they are made by code in that page, must be at standard speed. I guess you could do this by forcing full bus cycles for all the code there, even if sometimes those cycles end up in an internal rather than external memory write.)
Something along these lines should ensure that minimal code is caught in the I/O tarpit, and still let other separated code, such as compilers and linkers, run at high speed, including their access to the very disk buffers that were written at standard speed. And it should work regardless of whose code is doing disk I/O or where it is in memory.
I don't know how easily or efficiently this could be implemented on an FPGA. One major change it seems to introduce is that the "slow page" mappings now need to be dynamic, since they cannot be calculated and loaded at power-up or reset time. A plain old bitmap of which pages are affected would be only 32 bytes of memory for the 256 pages in the system, though.
By the way, that annotated Apple DOS listing I linked to above makes for good reading, if you're interested in that kind of thing, and can handle a fair amount of sarcasm. (I don't think the guy who wrote that had ever tried coding a large program in EDASM or a similar tool on an actual Apple II.)
I like it!
Thanks, cjs -- that is a neat idea. Along the same lines, maybe it would work to fall back into slow mode whenever a disk I/O address is accessed, and stay there until an RTS is encountered?
Also, a good point about needing to access all addresses externally while in slow mode. The "external code" mechanism I currently use is already running into a minor limitation in some of the chess computers under test: The programmer has used a PHA/PLA sequence within a loop to obtain a delay. (Lots of cycles for two bytes of code...) But since the stack is obviously running fast, we don't get quite the intended delay. In the chess computer that only means slightly higher-pitched tones, but a similar effect would obviously not be acceptable in Apple DOS routines.
That will need a new flavor of bus cycles in the replica, where data are fetched from internal RAM (where they may previously have been written by some fast code elsewhere), but nevertheless an external bus cycle is started to retain the timing. Which should, of course, be quite feasible.
I'll look into the implementation in more detail. Had gotten sidetracked over the past days by the suggestion of a (dare I say in a 6502 forum?) CDP 1806 replica... A lot of speed to be gained when replicating that processor, and an interesting task to mimic its external bus behavior, since the original CDP takes 8 clock cycles on the bus for every machine cycle!
