tokafondo wrote:
What do you think of this arrangment?
That looks good -- it agrees with the principle of as many connections as possible, in all directions. Possibly you don't need both the diamond
and the cross, but the extra effort is trivial, so I'd say go for it. Better to invest a few extra minutes doing something boring, as compared to wasting many "interesting" hours chasing gremlins.
Speaking of effort, I think you'll find it much easier to work with fine gauge wire, such as AWG 30 wire-wrap wire. That and other relevant topics are mentioned in my and Garth's posts
here. As he says,
resistance is not the enemy (meaning a thicker conductor isn't greatly helpful).
No need to twist Gnd and Vcc together -- simply being adjacent is almost the same thing. And a run of Gnd and Vcc would typically be shunted at each end by a bypass cap anyway, which makes the situation less critical. Remember, for the high frequencies we're worried about
a bypass cap acts pretty much as a piece of wire. That's why in my previous post I remarked that attaching to a bypass cap that goes to a ground grid is almost as good as attaching to a power grid. Hence you may choose to omit the power
grid per se. Instead it's okay to rely on bypass caps and the Gnd grid, and for Vcc distribution just have a fairly casual arrangement of wires, not a grid.
For gnd connections I often use uninsulated wire, and that works out well because it's less work to install -- I usually just solder it flat on the board. And of course there's quite a lot of wiring in the ground grid, so the effort saved is considerable. In contrast, my Vcc distribution is usually pretty minimal, using insulated wire.
