Commodore_PET wrote:
<snip> chip 74LS157 in UH4. on my board this is a DN74157N.
The 74 series logic has grown substantially over the years.
The 74yyy was the original range, for example 7400 is a quad 2-input NAND gates using TTL technology.
Later versions added one or more letters between the 74 part of the number code and the number indicating individual part number and therefore function.
Hence the next popular part is the 74LS00, which is also quad 2-input NAND gates (with the same pin-out), but this time using LS TTL technology (lower power requirements, that’s what the ‘L’ stands for.
There are other old technologies all using 74xxxyyy numbering, where xxx is one, two or three letters and the yyy denotes the function.
Since then there have been many more logic families based on the same functions, made with ever newer technologies.
Not all are compatible with one another, the vast majority that have the same number have the same function and the same pin-out.
However, for the most part, a 74LSxxx part can replace a 74xxx part. In many cases, as long as the power supply and power network can handle it, a 74xxx part can replace a 74LSxxx part.
In some cases, some functions in some technologies have become obsolete, or are no longer being manufactured. And some have never been available.
For the 74LS157, in some circuits these may sometimes be substituted by 74LS257 or 74HCT257.
Mark
