ironically i'm quite the opposite, i have never worked in the Hardware Design/ASCI field, but i've made a dozen of custom CPUs over the last few years.
it's easier than you think, atleast when you don't follow any specific feature/instruction set, or make a RISC CPU... those things are just really easy.
and to be honest, i make Verilog code the lazy way. i build my circuits in a Logic Simulator and just click a button that says "Export as Verilog", put that throught Quartus onto my FPGA Dev board, and there you.
and I don't know how auto generated code compares to manually written code in terms of resources and efficency.
so I don't think i would be the best for that job. especailly since i use a completely different internal architecture that is much more resource demanding than the original 6502's.
only good thing about my architecture are the decreased cycle times... which is mostly because I technically have 2 ALUs in my CPU.
about the 65C02, i can easily expand my 6502 design to a 65C02 without any major changes to the circuit. this is also why i want to start with the 6502, because once i have that working i can add new features without having to worry about any of the existing 6502 stuff.
Cheap FPGAs often don't have a lot of BRAM so i always try to minimize the usage of it.
but i could put the Zeropage or Stack onto the embedded RAM as it would only take up 512 Bytes, and it could speed up cylce times even more (single cycle push/pull instructions, imagine that!).
though for most testing i use BRAM to save myself having to build a circuit to interface with external RAM.
and lastly, i have no idea how i could optimize code for a specific FPGA family. my FPGA Dev board is a Cyclone II but I'm currently looking into Lattice FPGAs because they are basically the cheapest on the market while still fitting a bit into them. (for example i designed a simple color VGA core that fits into this FPGA while only using ~60% of it, making it a very cheap VGA option for any 8 bit computer).
so it was still helpful, though my current focus is to mainly get something working before i tackle any advanced versions of the 6502. (65C02, 65CE02, or something custom)
