Is anyone able to use VICE -remotemonitor on Windows? Do you get any output to monitor commands when you connect via telnet? If yes - what VICE version do you use? I was unable to get it in neither some old nor current GTK--based...
Plus - I was able to code first Wolin library function...
package pl.qus.wolin
var screen: ubyte[]^1024
fun chrout^0xFFD2(char: ubyte^CPU.A)
fun print(what: string) {
val i = 0
val znak = what[i]
while (znak != 0) {
chrout(znak)
i++
val znak = what[i]
fun main() {
print("dupa")
Due to not-so-fast function-stack arrays the code looks like ****, BUT IT WORKS, so who cares?
; setupHEADER
;* BASIC header
;* compile with:
;* cl65.exe -o assembler.prg -t c64 -C c64-asm.cfg -g -Ln labels.txt assembler.s
.org 2049
.export LOADADDR = *
Bas10: .word BasEnd
.word 10
.byte 158 ; sys
.byte " 2064"
.byte 0
BasEnd: .word 0
.word 0
; setupSPF=251[ubyte],40959[uword]
; prepare function stack
__wolin_spf := 251 ; function stack ptr
__wolin_spf_hi := 251+1 ; function stack ptr
__wolin_spf_top := 40959 ; function stack top
__wolin_spf_top_hi := 40959+1 ; function stack top
lda #<__wolin_spf_top ; set function stack top
sta __wolin_spf
lda #>__wolin_spf_top
sta __wolin_spf+1
; setupSP=114[ubyte]
; prepare program stack
__wolin_sp_top := 114 ; program stack top
__wolin_sp_top_hi := 114+1 ; program stack top
ldx #__wolin_sp_top ; set program stack top
; setupHEAP=176[ubyte]
__wolin_this_ptr := 176
__wolin_this_ptr_hi := 176+1
; call__wolin_pl_qus_wolin_main[uword]
jsr __wolin_pl_qus_wolin_main
; endfunction
rts
; function__wolin_pl_qus_wolin_print
__wolin_pl_qus_wolin_print:
; letSPF(1)<pl.qus.wolin.print..i>[ubyte]=#0[ubyte]
ldy #1
lda #0
sta (__wolin_spf),y
; letSPF(0)<pl.qus.wolin.print..znak>[ubyte]=&SPF(2)<pl.qus.wolin.print.what>[ubyte*],SPF(1)<pl.qus.wolin.print..i>[ubyte]
; dereferencing fast array passed as fn argument ain't fast, sorry...
; allocate pointer reg
dex
dex
; put (pointer + index) from function stack to regular stack
clc
ldy #2
lda (__wolin_spf),y
ldy #1
adc (__wolin_spf),y
sta 0,x
ldy #2+1
lda (__wolin_spf),y
adc #0
sta 1,x
; dereference/index the pointer
lda (0,x)
ldy #0
sta (__wolin_spf),y
inx
inx
; allocSP<__wolin_reg7>,#1
dex
; label__wolin_lab_loop_start_1
__wolin_lab_loop_start_1:
; evalneqSP(0)<__wolin_reg7>[bool]=SPF(0)<pl.qus.wolin.print..znak>[ubyte],#0[ubyte]
lda #1 ; rozne
sta 0,x
ldy #0
lda (__wolin_spf), y
bne :+
lda #0 ; jednak rowne
sta 0,x
; bneSP(0)<__wolin_reg7>[bool]=#1[bool],__wolin_lab_loop_end_1<label_po_if>[uword]
lda 0,x
beq __wolin_lab_loop_end_1
; saveSP
txa
pha
; saveSPF(0)<pl.qus.wolin.print..znak>[ubyte]
ldy #0
lda (__wolin_spf),y
pha
; restoreCPU.A[ubyte]
pla
; call65490[uword]
jsr 65490
; restoreSP
pla
tax
; addSPF(1)<pl.qus.wolin.print..i>[ubyte]=SPF(1)<pl.qus.wolin.print..i>[ubyte],#1[ubyte]
clc
ldy #1
lda #1
adc (__wolin_spf),y
sta (__wolin_spf),y
dex
dex
clc
ldy #2
lda (__wolin_spf),y
ldy #1
adc (__wolin_spf),y
sta 0,x
ldy #2+1
lda (__wolin_spf),y
adc #0
sta 1,x
lda (0,x)
ldy #0
sta (__wolin_spf),y
inx
inx
; goto__wolin_lab_loop_start_1[uword]
jmp __wolin_lab_loop_start_1
; label__wolin_lab_loop_end_1
__wolin_lab_loop_end_1:
; freeSP<__wolin_reg7>,#1
inx
; freeSPF<pl.qus.wolin.print.__fnargs>,#4
clc
lda __wolin_spf
adc #4
sta __wolin_spf
bcc :+
inc __wolin_spf+1
; endfunction
rts
; function__wolin_pl_qus_wolin_main
__wolin_pl_qus_wolin_main:
; allocSPF,#4
sec
lda __wolin_spf
sbc #4
sta __wolin_spf
bcs :+
dec __wolin_spf+1
; letSPF(2)[ubyte*]=#__wolin_lab_stringConst_0[uword]
lda #<__wolin_lab_stringConst_0
ldy #2
sta (__wolin_spf),y
lda #>__wolin_lab_stringConst_0
iny
sta (__wolin_spf),y
; call__wolin_pl_qus_wolin_print[uword]
jsr __wolin_pl_qus_wolin_print
; endfunction
rts
; string__wolin_lab_stringConst_0[uword]=$"dupa"
__wolin_lab_stringConst_0:
.asciiz "dupa"
