It is currently Sat Nov 16, 2024 9:40 pm
PostPosted: Wed Dec 25, 2019 4:26 pm
1st, happy holidays!
2nd, I was just watching John Wick 3 and noticed a CBM machine and took a pic. I googled it and apparently the Vic20 was used in John Wick 2. I had missed that one, but here is a snapshot from JW3.
PostPosted: Wed Dec 25, 2019 8:37 pm
Nice... and apparently driving an original IBM Monochrome display no less, which wouldn't work out of the box.
PostPosted: Fri Jan 03, 2020 1:57 pm
Gotta love the cigarette smoke and rotary phone. A must for any real computer setup.
PostPosted: Thu Feb 06, 2020 9:21 pm
Also properly vintage is the placement of the monitor off to the side of the computer. I've never understood that. It's terrible ergonomics, yet a computer desk was very commonly presented that way.
PostPosted: Thu Feb 06, 2020 10:11 pm
Hah, nice observation. I believe her cig was of primary concern.... I mean if you're a director and put that kind of detail into a shot, no doubt they would have thought this through.
PostPosted: Thu Feb 06, 2020 11:12 pm
A colleague of mine in the past used to joke she chain-smoked her way through many a debugging session—back when corporations allowed employees to smoke inside the building. It was true. She'd be hunched over the terminal with a hard copy of the source code next to her looking more like a coal-fired steam locomotive than the expert programmer she was. She was a very dear friend, but I couldn't stand the second-hand smoke, so we seldom worked together. But I will say her stuff always worked and worked well.
Alas, all that heavy smoking got her and she died from lung cancer at the relatively young age of 59. :cry:
PostPosted: Fri Feb 07, 2020 8:49 am
And driving it at 40 columns, no less! Clearly that VIC-20 has a custom video adapter.
You need access to the back of the VIC-20 to insert cartridges. A serious power user would have a VIC-1010 expansion unit to allow using multiple cartridges (such as RAM expansions, peripherals, and a ROM cartridge) at the same time:
The cartridge slot was at the right of the VIC-20, as you face the front; the expansion unit thus extended well past the right edge of the VIC-20 itself. (This was to avoid blocking other ports on the back of the VIC-20.) These old systems could use quite a lot of desk space.
PostPosted: Fri Feb 07, 2020 1:50 pm
The video system of the VIC-20 is surprisingly flexible. It was common for custom "drivers" to be written to get more than the standard 22 columns. I don't know if they hit 40, but I think they got close.
PostPosted: Fri Feb 07, 2020 2:52 pm
Indeed:
40 Columns in Basic on the Commodore VIC-20
Although that's using a tiny font rather than tiny pixels...
But see also (all from the same article)
And there's a video
PostPosted: Fri Feb 07, 2020 3:08 pm
Yep. It's really an amazing (and often overlooked) machine.
Over on the Denial forums, one of those guys even managed to get "hi-res" out of it with a relatively simple internal mod.
PostPosted: Sat Feb 08, 2020 4:39 am
As other have pointed out, systems that reworked the use of the existing video display hardware were able to generate 40 colums. I've personally used, in an emulator, a couple of systems that do this.
However, the 40-column mode you see on the screen looks very different from any of the 40-column modes I've used on the VIC-20, and I don't think you could get a screen display that looks like that out of an unmodified VIC-20.
