It is currently Fri Nov 22, 2024 6:27 pm
 Post subject: EEPROM Programmer
PostPosted: Wed Oct 16, 2019 11:22 pm
Hello everyone. I'm quite new to the 6502. I was inspired by Ben Eater's great YouTube video, and I'm having a lot of fun.
One thing I noticed right away was that I needed a way to easily program the AT28C256 in my design. I came up with a programmer based on the ESP32 that allows you to program it by putting your hex dump into a web page and sending to the EEPROM.
You can find my designs here: https://easyeda.com/rick_9005/eeprom-programmer_copy
It's still a work in progress, and things might change, but if you're interested in the code, let me know. I'd be happy to share it (I'm not a great programmer, and some decision were made because the design changed, but it does work--most of the time).
Rick
 Post subject: Re: EEPROM Programmer
PostPosted: Thu Oct 17, 2019 6:23 am
Welcome! Good idea to use the ESP32 (cheap, and easy to program, I think.) And the bootstrapping problem - how to program your first EPROM - is always with us.
Please do share your code - ideally, put it up on github or gitlab, and ideally attach one or other of the usual licenses to it.
PostPosted: Fri Oct 18, 2019 12:28 am
Thanks, BigEd!
I'm not at the computer with the code on it "write" now (see what I did there?), so I'll post it later, but I will post it.
One thing I want to say is that I know the AT28C256 is 5V chip and the ESP32 is a 3v3 chip. The data sheet for the AT28C256 says 5v +- 10%, which is still more than 3v3. I figured, it couldn't hurt to try. The worst that would happen is that it wouldn't work. If it were the other way around, it would be a different story, but since I'm supplying less voltage, it would be OK. And it was.
PostPosted: Fri Oct 18, 2019 7:39 am
Oh, that's quite surprising, if you can program a 5V EPROM using a 3V3 system. It's possible the result will not be reliable, if it was unable to raise its internal voltage high enough. Might be worth programming the same contents two or three times. Or, just program it the once, but be on the lookout for decay of the memory contents. It would be bad to spend a long time trying to figure out a bug later, if the cause was that the ROM had lost a few bits.
PostPosted: Fri Oct 18, 2019 9:29 am
From the datasheet, MCP32S17 and MCP32S08 can operate at 5V.
ESP32 power supply is specified 3.6V max.
An option would be buffering the ESP32 SPI interface by placing 74LVC245 chips between the 3.3V powered ESP32 and the 5V powered MCP32S17\MCP32S08.
74LVC245 doesn't mind which side is 5V, so one could tie the DIR pin to GND or 3.3V when creatively arranging the 3.3V and 5V signals.
Example:
Edit: the 74LVC245 has to be 3.3V powered, of course.
PostPosted: Tue Dec 03, 2019 2:15 am
This is an old post, but I ended up giving up on the idea because when I tried to load a large program into the rom through the web interface, it failed to even load the web page. 32k is just too much to submit to the ESP32 over a simple web interface.
PostPosted: Tue Dec 03, 2019 1:06 pm
It's always good to read back the ROM after it's programmed and verify that the contents match what you programmed.
PostPosted: Tue Dec 03, 2019 2:59 pm
I agree. My code was setup to write data to the ROM and then read it back to verify it was done correctly.
I had another programmer I made with an ATMEGA328 and some SPI GPIO chips, but it was slow, and I've abandoned that, too.
PostPosted: Tue Dec 03, 2019 7:11 pm
I think what Ed's getting at is that if it's on the raggedy edge of working, reading it back might give the right result and yet it may not be dependable later when for example temperature changes or a few months or a year or two go by.
PostPosted: Tue Dec 03, 2019 7:26 pm
That could absolutely be true. For right now, I'm in it for the short haul. And I mean the 5 minutes it takes to run what's there, and then debug and reprogram to try and fix what didn't work.
But, like I said, I abandoned this programmer, and the other programmer I built, and bought a commercial one (T866II). It works much better than what I built, and, as you point out, it's probably much more reliable.
Rick
PostPosted: Tue Dec 17, 2019 8:21 pm
On my KIM-1 6530 replacement circuit, I needed to be able to do either 6530-002 and 6530-003 chips. So, I programmed the EEPROM right on my adapter with code on my debug monitor board. I just do it in place, on the KIM-1. You'd want to have a separate memory location for your programmer code though. It wasn't two hard to do. Most EEPROMs have software locks to protect from accidental over writing but I just used a jumper wire that can be cut.
Dwight
Users browsing this forum: pdragon and 41 guests
