Thanks Garth!
I could extract this page:
If I'm not too drowsy then 1MOhm x 1uF would yield 1 s.
If using a (trim)pot for R use an additional resistor (e.g. 1K or more) in series with the pot as a sort of safeguard (just don't short output to input).
Regards
Flexible clock circuit
Re: Flexible clock circuit
I was going to post links to NSC (later Fairchild) ap. notes, but when ON Semi took over Fairchild, they wiped them out. I've been able to get them to re-post some of them, and now I just sent another email asking for these two, which I have old links to on my 6502 primer's clock-generation page and just realized I still need updated links to:
HCMOS crystal oscillators (AN-340) and
CMOS oscillators (AN-118)
I have them on paper but unfortunately not in electronic form to attach here. I plan to update this (as well as the links on my website) when I hear back from ON Semi.
- GARTHWILSON
- Forum Moderator
Thanks, Ed. I still need to tune my thinking to more quickly go to archive.org when something is gone. In this case of course it's not my web page (we back up the whole site a couple of times a day anyway), but rather the ap. notes.
So here's one: https://web.archive.org/web/20180311021 ... AN-340.pdf
Here's the other: https://web.archive.org/web/20170904003 ... AN-118.pdf
I just now made the links on the page point to these on archive.org.
GaBuZoMeu wrote:
Thanks Garth!
I could extract this page: If I'm not too drowsy then 1MOhm x 1uF would yield 1 s.
Regards
Regards
Thanks
- GARTHWILSON
- Forum Moderator
joanlluch wrote:
I would still need an edge triggered J-K flip flop after that to obtain a proper 50% duty cycle (half frequency) signal, is this right?
Thanks
Thanks
Instead of a J-K FF I would choose a D-FF (with /Q wired to D) but that is only a personal preference.
If you wish to run your circuitry with less than 1 Hz, say 1/10 Hz or even 1/100 Hz you can use a binary counter like a 74HC4040 and choose one of its twelve outputs each at 1/2 speed of its preceding one and each truly symmetrical. Just take a look at page 5 of the datasheet.
The 74HC4060 (datasheet) is handy for slow clocks, as it has an oscillator circuit and dividers all in one chip
The oscillator can either be a RC type or a crystal type.
Mark
Mark
