It is currently Sun Sep 29, 2024 6:11 pm
 Post subject: Re: C=Hacking Issue #8
PostPosted: Mon Nov 11, 2019 1:20 pm
A0CBM wrote:
I don't know how to handle the term on the right: cos(z)sin(y)sin(x), to get rid of the multiplications.
You just apply the identities twice:
cos(z)sin(y)sin(x) = cos(z)(cos(y-x) - cos(y+x))/2
                   = (cos(z)cos(y-x) - cos(z)cos(y+x))/2
                   = (cos(z+y-x) + cos(z-y+x))/4
PostPosted: Mon Nov 11, 2019 5:02 pm
Been following this thread.
It appears that the desire is to convert the elements of the 3D rotation matrix from products of trig functions to sums of trig functions. This appears to be motivated by a desire to reduce the number of multiplies. This is a laudable goal if not for the fact that the trig functions themselves will require many multiplications to evaluate to a desired level of accuracy.
I suspect that the processing time savings achieved by a reduction in the number of multiplies present in the 3D rotation matrix elements will be swamped by the number of additional trig functions that will be required to represent the elements as sums instead of products. Assuming that a trig function evaluation consists is 8x longer than a multiply, the evaluation of the element
cos(z)sin(y)sin(x) as [cos(a) + cos(b) - cos(c) - cos(d)] / 4
will result in 8 + 8 + 8 + 2 operations versus 8 + 8 + 8 + 8 operations (assuming divide by 4 is free). Thus, evaluation of the product form will require approximately 26 operations and the evaluation of the sum form will require approximately 32 operations. This makes the product form more efficient than the sum form.
I am not seeing a path where the number of trig function evaluations is reduced by converting from the product form to the sum form. It is an interesting exercise in using trig identities, but I am not seeing the benefit to the exercise.
Am I missing something?
Michael A.
PostPosted: Mon Nov 11, 2019 5:38 pm
Hi!
Yes.
You can evaluate the trigonometric functions with the required precision (8 bits) with a simple table lookup, so it is faster than a standard multiplication.
Have Fun!
PostPosted: Mon Nov 11, 2019 5:54 pm
I guess I forgot that you're doing these transforms for a low precision application: you're not navigating to the moon and back. :D So yes, as you suggest above, table look ups for the trig functions is a great approach and the resulting simplification of the trig function evaluation would result in the sum form being much faster than the product form.
Michael A.
PostPosted: Tue Nov 12, 2019 7:46 pm
I had a feeling there was a way and I thought about applying the identity twice, but didn't know how to approach it. That makes sense. Let's see if I can figure out any more of that article. Now I can try and figure out T1 through T10, which I'm sure has something to do with the amount of rotation. This is my own personal challenge. I appreciate everyone's help and I'm sure I'll encounter more that I need help to figure out.
Thanks.
PostPosted: Wed Nov 13, 2019 8:11 pm
cos(z)cos(y-x) = (cos(z - (y-x)) + cos(z + (y-x)))/2
cos(z)cos(y+x) = (cos(z - (y+x)) + cos(z + (y+x)))/2
PostPosted: Wed Nov 20, 2019 8:36 pm
OK, I'm lost. After multiplying out rotation matrices X,Y, and Z, position 1,1 is cos(z)cos(y) which equals (cos(z-y) + cos(z+y))/2, so T1 = z-y and T2 = z+y? The article has t1 = sy - sz and t2 = sy + sz. Why are my z and y turned around?
Users browsing this forum: Google [Bot] and 8 guests
