x64
I am a software engineer with a passion for older home computers, and just recently started writing some simple programs in assembly for the C64.
I downloaded VICE and cc65, and compiled the sample programs. Most work well, except for the ones that make use of the TGI driver.
https://github.com/cc65/cc65/blob/maste ... /tgidemo.cIf DYN_DRV is set to 1, the program complains about not being able to load the driver. I suspect that I need to somehow make the driver’s object file available to VICE, but I don’t really understand how.
If I set DYN_DRV to 0, it runs just fine. I assume the driver is being linked into the final executable.
Can you help me figure out how to run TGI with a dynamically linked driver?
