It is currently Sat Nov 23, 2024 4:14 am
 Post subject: PC push/pop with Branch?
PostPosted: Thu Aug 22, 2019 10:22 pm
Is it possible to manually push and pop the PC with the 65816?
I need to do PC relative jumps but can't really think of a reasonable way to jump back. Any ideas?
PostPosted: Thu Aug 22, 2019 10:26 pm
PER?
PostPosted: Thu Aug 22, 2019 10:32 pm
Instructions that come to mind for pushing the program counter are PEA (push 16-bit effective absolute address, although it can also be data, or it can be the address of the PC if it's known at assembly time), PER (push 16-bit effective relative address, and can be your actual address if you don't give it an offset), PHK (push program-bank register), and of course JSR and JSL. Instructions that pull the PC off the stack are RTS, RTL, RTI. (Be careful about the one-byte difference between return-from-interrupt and return-from-subroutine.) There are more ways to skin this cat, but these are the main ones that immediately come to mind. Other members who have more '816 experience than I have will undoubtedly chime in with more ideas.
Chapter 13 of the 6502 stacks treatise, "65816's instructions and capabilities relevant to stacks, and 65c02 code which partially synthesizes some of them" http://wilsonminesco.com/stacks/816newinst.html addresses this kind of thing.
PostPosted: Thu Aug 22, 2019 11:18 pm
Thank you!
I did it with the PER instruction. Took me a moment to figure out how to calculate the relative offset correctly.
PER  return
BRA  subroutine
return: NOP
subroutine:
RTS
The NOP is needed for a correct return address.
PostPosted: Fri Aug 23, 2019 3:29 am
The NOP is one solution, but not the only solution. :)
PER  return-1              ; <-- altered. ( Was PER return )
BRA  subroutine
return:                    ; <-- altered. ( NOP removed )
subroutine:
RTS
PostPosted: Fri Aug 23, 2019 8:08 am
YES! That's even better, thank you! :)
PostPosted: Fri Aug 23, 2019 8:19 am
I'm late to the party here, but what you want is the equivalent of the BSR instruction found in the Motorola 68K MPUs. It can be easily written as a macro:
;   BSR: Branch to Subroutine
;   This macro synthesizes the BSR instruction implemented in the Motorola
;   6800 & 68000 microprocessors.  Programs in which subroutines are call-
;   ed via BSR are fully relocatable,  as the target address is calculated
;   relative to the program counter at run-time.   The target address must
;   be within the range of a long relative branch, +$7FFF or -$8000 bytes.
bsr      .macro .sr            ;BSR <addr>
.mib     =$82
.mip     =$62
.na      =*+3
.ra      .set .na+2
.ba      =.ra+1
.ra      .set .ra-.na
.ta      .set .sr-.ba
         .byte .mip,<.ra,>.ra,.mib,<.ta,>.ta
         .endm
The above was written to synthesize BSR <ADDR> on the '816, using the Kowalski simulator to assemble the source code. It takes advantage of BRL (long relative branch) and PER.
PostPosted: Fri Aug 23, 2019 8:29 am
Thanks BDD. So, I think that's a variation with greater range than Jeff's:
BRL  subroutine
subroutine:
RTS
versus
BRA  subroutine
subroutine:
RTS
PostPosted: Fri Aug 23, 2019 11:28 am
BRL  subroutine
subroutine:
RTS
versus
BRA  subroutine
subroutine:
RTS
Had to use the BRL in the end, yeah... What I do not understand is: Why do I exit with RTS and not RTL after BRL?
PostPosted: Fri Aug 23, 2019 2:52 pm
Not all "xxL"s are created equal.
BRL is the "16-bit flavor" of the 8-bit BRA. BRL can't break out of the current code bank, so there's no need to save that bit of state (which is a good thing, since PER only pushes 16 bits of address). So RTS is the proper return instruction.
JSL is the "24-bit flavor" of the 16-bit JSR. It does need to save the code bank state, so it pushes a 24-bit return address, which is expected by RTL.
PostPosted: Sat Aug 24, 2019 1:39 am
If you need to emulate JSL, perhaps because you need a long-indirect (which JMP provides) rather than only a 16-bit indirect, then you can use the following:
 PHK
 PER return-1
 JMP [fn_ptr]
return:
In that case you would return with RTL.
PostPosted: Sat Aug 24, 2019 5:03 am
 PHK
 PER return-1
 JMP [fn_ptr]
return:
Why not just use the JSL instruction with the self-modifying code and let the '816 do the stack grunting?
