Yes, Yorkshire is definitely a bit too far from London for a drop-off!
I appreciate the main board needs some attention. The sockets need cleaning & the reset circuit is a bit temperamental. And the NVRAM is quite old.
So I've priced it accordingly.
£30 UKPounds for the main board and the programming board (for the NVRAM).
And £15 for the stepper motor and driver board (if you don't require the stepper motor & board then that's fine as I will probably find a use for it).
Shipping at cost.
Manual & floppy disks included.
Regards
Andy
London is quite some distance from North Yorkshire, I think. I actually saw a board outside a local pub, advertising "the last decent coffee before London" - bearing in mind it was right outside the station.
The trick is that I don't have a permanent address here to give you, and then I'd have to find some way to squeeze it into my already overstuffed luggage. It'll be easier to sort out when I'm back home in Finland, even if the postage takes longer.
What price were you thinking of?
