It is currently Fri Nov 15, 2024 2:27 am
PostPosted: Mon Jul 22, 2019 6:58 pm
OK, I'm slowing doing some bits and pieces in my little Ruby OS to 816-ify it... and there's one little thing that I'm finding just weird. I'm probably missing something completely obvious, but right now can't see it ...
For the most part I'm running in native 816 mode with 8-bit registers.
I have a memory-fill routine. Thought I'd be clever and use the 816 block-move instruction. The code takes the value from the command line via an 'atoi' routine (understands decimal, $hex or %bin) and stores it in a 16-bit memory location in page 0 called atoi0 and atoi1, so then ...
; Fill 0000 to the start of RubyOs
        sei                     ; Just in-case
        lda     atoi0
        sta     $0              ; Store at 0
; '816 fill
        aix16
        lda     #rubyCold-1     ; Number of bytes
        ldx     #$0000          ; Start
        ldy     #$0001          ; End
        mvn     0,0             ; block move
        aix8
        jmp     rubyOs
The aix8 and aix16 instructions are macros:
; aix8: aix16:
;       Index and A registers into 8 or 16 bit mode
.macro  aix8
        sep     #$30
        .i8
        .a8
.endmacro
.macro  aix16
        rep     #$30
        .i16
        .a16
.endmacro
This is ca65 and .a8/16 and .i8/16 are used to indicate to the assembler to use 16 bit or 8 for Acc or XY.
The assembler list output is as I'd expect:
00018Br 1  A5 EC                lda     atoi0
00018Dr 1  85 00                sta     $0              ; Store at 0
00018Fr 1
00018Fr 1               ; '816 fill
00018Fr 1
00018Fr 1  C2 30                aix16
000191r 1
000191r 1  A9 FF CF             lda     #rubyCold-1     ; Number of bytes
000194r 1  A2 00 00             ldx     #$0000          ; Start
000197r 1  A0 01 00             ldy     #$0001          ; End
00019Ar 1  54 00 00             mvn     0,0             ; block move
00019Dr 1
00019Dr 1  E2 30                aix8
00019Fr 1
00019Fr 1  4C rr rr             jmp     rubyOs
Anyway, here is the odd bit. This works for all values I've tested except zero. If I ask it to fill with zeros, then it crashes in an obscure way and scribbles over memory with a repeating 4-byte pattern: $37, $00, $35, $37 ...
I've tried changing the lda atoi0 with lda #$0 and it fails the same way (but works for other values I've tried).
So have I missed something obvious, being stupid, or something else?
Any clues welcome!
 Post subject: Re: '816 odditys ...
PostPosted: Mon Jul 22, 2019 7:22 pm
Please forgive me if these are silly questions, but:
1) do you have any NMIs and
2) is your subroutine located in bank 0 RAM, causing you to sled all the way to your cold start after the move?
PostPosted: Mon Jul 22, 2019 7:44 pm
barrym95838 wrote:
Please forgive me if this is a silly question, but is your subroutine located in bank 0 RAM?
Yes - there is only one bank of 64K in this system. The routine should clear from $0000 to $CFFF.
The code lives in higher RAM - the addresses in the listing output are relocatable ones generated by ca65.
PostPosted: Mon Jul 22, 2019 8:08 pm
OK. I have worked it out.
It's the count.
According to the book, you set count -1 in the 16-bit A register.
So I was setting the address of the start of the OS ($D000) minus 1. I've "manually" written the first byte, and I'm copying one less (to location 1), so I really ought to have -2 in there.
And when I do that it works.
It wasn't working before because I've not got the '816 BRK vector setup, so if it jumped to $D000 after the copy, it hits a BRK which goes to ($FFE6) in '816 mode which "blows up". With all the other numbers I tried, it seemed to just work - or skipped over them. Lucky I guess, but led me down the wrong path.
So, ok, as you were, please have a chuckle at me in my Gordon is a moron moment (old UK folks will know that one)
PostPosted: Mon Jul 22, 2019 11:34 pm
Nicely done. I knew you probably had the best chance of solving the issue, being reasonably competent and situated right there and all ... 8)
https://www.youtube.com/watch?v=LTKORcr1jhY
Users browsing this forum: Yuri and 10 guests
