It is currently Thu Nov 14, 2024 4:56 am
PostPosted: Wed Jul 10, 2019 2:30 pm
Let's see you load a constant (let's say $42) without using any immediate values. Short programs, and surprising tactics, are better! (Edit: for example, get $42 into the accumulator, using 6502 instructions only. But if you have a remarkable solution using '816 instructions, go for it.)
Here's a spoiler-proof fence so you can have a go before you see anyone else's effort:
More fence:
PostPosted: Wed Jul 10, 2019 3:09 pm
This is the first way I though of doing it:
; Load $42 = 01000010 into A without using immediates
ASL A  ; 0
SEC
ROL A  ; 1
ASL A  ; 0
ASL A  ; 0
ASL A  ; 0
ASL A  ; 0
SEC
ROL A  ; 1
ASL A  ; 0
Total is 10 bytes / 20 cycles.
You can probably do better with code assembled at a specific address, so that JSR will push a know value onto the stack.
PostPosted: Wed Jul 10, 2019 3:53 pm
Expanding on your idea, for constant time using the C02
Set A to $FF first, then ASL A shifts in a zero ROL A shifts in a 1 without needing additional SEC instructions
LDA $00   ; (2/3) any zero page location
EOR $00   ; (2/3) A is now zero
DEC A     ; (1/2) A is now $FF
SEC       ; (1/2) set the initial carry
ASL A     ; (1/2)
ROL A     ; (1/2)
ASL A     ; (1/2)
ASL A     ; (1/2)
ASL A     ; (1/2)
ASL A     ; (1/2)
ROL A     ; (1/2)
ASL A     ; (1/2)
Longer and slower at 14 bytes and 26 cycles, loading $42 but will be the same for any constant as the carry is set on every shift/rotate.
However for the best time, with A at known state at the start, there's no need to shift in any leading 1. The SEC isn't needed, as the first bit shifted in will be a zero. So to load say $F7 would be shorter at 9 bytes and 16 cycles.
ASL A     ; (1/2) A is now $FE
ROL A     ; (1/2) A is now $FD
ROL A     ; (1/2) A is now $FB
ROL A     ; (1/2) A is now $F7
Obviously the trivial case is set A to zero, that's just 4 bytes and 6 cycles.
PostPosted: Wed Jul 10, 2019 4:08 pm
For $42 specifically, I can do better:
STZ $FE ; clear A via ZP
LDA $FE
SEC
ROR A
ROR A ; $40
INC A
INC A ; $42
That's 9 bytes, 16 cycles, given a 'C02.
For a more general approach, let's do some preparation by loading $FF into a ZP location (again, assuming a 'C02):
STZ $FF
DEC $FF
Then, every time you need to load a constant, you can encode it directly into a pattern of RORs and LSRs, as C will be implicitly set by each:
LDA $FF
SEC ; only actually needed if LSB is to be set
LSR A
ROR A
LSR A
LSR A
LSR A
LSR A
ROR A
LSR A
That's 11 bytes, 21 cycles - or if you can elide the SEC, 10 bytes, 19 cycles. You can turn it around and use ROL/ASL if the MSB happens to be clear, and shorten the sequence if several most-significant or least-significant bits are all set. This code segment is even NMOS compatible!
PostPosted: Wed Jul 10, 2019 7:42 pm
And, for a borderline-cheating solution:
LDA $42
LDA *-1
That's 5 bytes, 7 cycles (assuming the program is not in ZP).
PostPosted: Thu Jul 11, 2019 4:02 am
LDA $42
LDA *-1
Definitely my favorite! The challenge seems rather contrived from the start, but I am reminded of a situation like this (or more specifically this), where Ivan needed to include his run-time machine code in "keyboardable" Applesoft REM statements (UPPER-CASE only for full compatibility), allowing the inclusion of only a small subset of the 6502 opcodes and operands (no LDA LDX LDY STA STX STY ...).
PostPosted: Thu Jul 11, 2019 5:29 am
Even better: if you have STY zp anywhere - which seems likely, or at least easy to arrange - then attach a label to it. Its opcode is $84. Then you only need:
LDA sty
LSR A
That's 4 bytes, 6 cycles. You can do the same with STA zp, which is $85.
Slightly less likely is that you have CMP (zp,X) or AND (zp,X) somewhere. Use the same trick on these, but with ASL A. If you have EOR (zp,X), use INC A.
PostPosted: Thu Jul 11, 2019 6:27 am
Nicely done, everyone. I did (eventually) think of setting carry and shifting, but at the moment of posting I didn't have an answer. I thought of looking at the stack, but not of reading the code itself.
Thanks for the pointer back to SLAMMER - that's a well-motivated case of constrained programming. We've also previously seen the case of avoiding 00 in code:
Bootstrapping an SBC
Edit: some links to SLAMMER have decayed - see this post and this one for working links.
Edit: or, I could fix up this quote:
barrym95838 wrote:
...I am reminded of a situation like this (or more specifically this), where Ivan needed to include his run-time machine code in "keyboardable" Applesoft REM statements (UPPER-CASE only for full compatibility), allowing the inclusion of only a small subset of the 6502 opcodes and operands (no LDA LDX LDY STA STX STY ...).
Edit: for want of a better place to put it, a link to Neal Parker's
S. H. Lam Revisited
PostPosted: Thu Jul 11, 2019 10:30 am
If it's possible to place code anywhere, the stack could be used using a JSR to the next line of code, then popping the address which just happens to be $42.
It's possible to load two immediate. But the code has to be in just the right place.
http://www.finitron.ca
PostPosted: Thu Jul 11, 2019 10:41 am
Some of these approaches, of course, need the assembler to know the load address - position-independent code being another kind of constraint on programming.
PostPosted: Thu Jul 11, 2019 1:50 pm
It may also be possible to rely on the contents of a ROM. But that makes the code less portable.
PostPosted: Thu Jul 11, 2019 1:54 pm
Yes, if you are running on a known system with significant amount of fixed ROM data, of course this makes the task so much easier. So much so, that it could be felt to be cheating :lol:
Mark
PostPosted: Thu Jul 11, 2019 3:31 pm
... constraint on programming.
I have an apt solution to Ed's mini challenge, but I have hesitated to mention it because it involves a constraint on the hardware. Here is my somewhat dubious solution:
LDA $4200
The constraint is that $4200 is an address which causes no device to be selected, as may for example may be the case on an older system equipped with 16K or less of RAM. Thus, during the 4th cycle of the LDA abs -- when the target address is supposed to be read from -- nothing will drive the data bus. In that circumstance, capacitance will cause the bus to retain its last actively driven value... in this case, the high byte of the LDA's 16-bit operand.
PostPosted: Thu Jul 11, 2019 4:25 pm
Mr Hyde, that's fiendish!
(Might be worth noting that tactics like STZ/LDA or LDA/EOR also rely on something - both could fail if they happened to hit peripherals which don't happen to return the expected data.)
Users browsing this forum: Google [Bot] and 12 guests
