It is currently Wed Oct 02, 2024 4:34 am
 Post subject: 6502 timing logic
PostPosted: Thu May 16, 2019 5:35 pm
As far as I know all the timing logic related states are T0, T+, T2, T3, T4, T5, T1, V0, T6, SD1 and SD2. I'm having a bit trouble finding some of these nodes from visual6502.
The ones I have found are (but not sure if all are correct):
T2 (node: 971)
T3 (node: 1567)
T4 (node: 690)
T5 (node: 909)
T1 (node: 862)
V0 (node: 1465)
T6 (node: 1481)
I think nodes 16 and 1357 are used for timing logic, but I'm not sure which ones they are (might be T0 and T+). #VEC might be one of the states with a different name too. SD1 and SD2 are the ones I don't think I've been able to getting even close to finding.
Can someone give me some directions for the missing nodes and correct any incorrect information
 Post subject: Re: 6502 timing logic
PostPosted: Thu May 16, 2019 6:43 pm
I posted some pointers for further reading here:
viewtopic.php?p=58631#p58631
See if that helps.
PostPosted: Thu May 16, 2019 7:51 pm
Here you go....
PostPosted: Thu May 16, 2019 8:07 pm
(Thanks!)
PostPosted: Thu May 16, 2019 9:14 pm
Found some more:
PostPosted: Thu May 16, 2019 9:15 pm
And don't forget ACR:
PostPosted: Fri Jun 14, 2019 4:47 pm
Sorry for the long delay
Thanks for the pictures. I was a bit curious if you can find more of these pictures somewhere?
PostPosted: Sat Jun 15, 2019 6:33 pm
What else do you need? :wink:
PostPosted: Mon Jun 17, 2019 9:56 am
This should be the PLA/Decode rom without ROR bug:
I compared it to the die shot... and fixed the schematics. However no guarantee I missed something else. :)
PostPosted: Fri Jun 21, 2019 11:11 am
Nothing in particular, just wondering if you can find them on a website or something. It would be useful reference if I ever need it.
