It is currently Sun Apr 28, 2024 7:24 pm
PostPosted: Sat May 04, 2019 8:42 pm
Just read this and thought it worth repeating here:
So provided that the memory block I wanted to move resided in the bottom 64K of RAM, and provided I didn't need to move it outside that region (both of which conditions were true for the screen-scrolling stuff I was writing at the time) I could load Direct Page with the end address of the source block, turn off interrupts, load the stack pointer with the end address of the destination, and run an unrolled sequence of PEI instructions to do the move. At 6 cycles per two bytes moved that came to 3 cycles per byte, more than twice as fast as the inbuilt memory move instruction.
(Posted by flabdablet here with this preamble for context)
PostPosted: Sat May 04, 2019 8:45 pm
(Lots of other interesting low-level programming quips in that thread.)
PostPosted: Sun May 05, 2019 10:04 am
I don't see the optimization here.
Ok so PEI pushes two bytes (6 cycles) but you then have to modify the address to point at the next pair (two zero page DECs as the transfer is towards low memory 10 cycles), test for the end of the transfer (assuming word count is in X or Y then DEX/DEY is 2 cycles) and branch back to go around again (BNE is 3 cycles on all but the last branch).
So in total its 6+10+2+3 = 21 cycles per word or 10.5 per byte which is worse than MVP/MVN.
Andrew Jacobs
PostPosted: Sun May 05, 2019 10:10 am
Hmm. Indeed. How odd - it works as a block fill with a fully unrolled sequence of PEI, which could be useful in a scroll routine to clear the new line, but it isn't a block move.
PostPosted: Sun May 05, 2019 1:24 pm
This flabdablet character is capable of some seriously twisted thinking. 8) :shock: Here's my take on his/her impressive hack.
The inner loop is tidy, and would look like this (below). I chose to unroll by eight, but only to keep the illustration brief. To make the thing worthwhile you'd want to unroll further than that.
All the surrounding code (which I didn't bother to work out) would be rather untidy. You'd have to start by setting up the Stack Pointer and the Direct Page Register; and check that at least 16 bytes remain to be moved before each iteration of the inner loop is allowed to proceed. After the final iteration you'd need to use conventional coding to move the remaining bytes, if any. (Depending on circumstances, you might be able to ensure there are none.)
PEI $E
PEI $C
PEI $A
PEI $8
PEI $6
PEI $4
PEI $2
PEI $0
TDC
SEC
SBC #$10
TCD
To avoid a one-cycle penalty for every PEI, you need the low eight bits of the Direct Page Register to equal zero -- IOW keep D page-aligned. For that you'd have to unroll the loop so it contains 128 PEI's -- a reasonable tradeoff, if speed is a priority and memory is cheap.
Edit: this hack works out wonderfully if the block-move source, destination and length are known in advance (as in flabdablet's screen-scrolling scenario). For general use it'll be comparatively clumsy, but still worth pursuing if the block-moves are fairly large.
PostPosted: Sun May 05, 2019 2:34 pm
Ah! It's the PEI argument which increments! (Edit: double-decrements. Oops. Not my day.)
BTW I think this might have been noted before, but with a bit of care, or luck, there's no need to disable interrupts: the ISR's stack frame will shortly be overwritten as the block move proceeds. I think.
PostPosted: Sun May 05, 2019 3:12 pm
Its a rather specialised block move. Up to 256 bytes from a fixed set of addresses.
Andrew Jacobs
PostPosted: Mon May 06, 2019 1:54 am
A fixed set of addresses is what will produce maximum efficiency, because the registers' initial values won't have to be computed at run-time as part of the setup. And of course fixed length would improve efficiency, too.
That said, a more general routine (one that accepts arbitrary addresses and length) will more than recoup the setup overhead if enough bytes need to be moved. I don't have an exact figure for "enough" because I haven't coded the routine. But it won't take much to pass break-even and start to show a profit. The inner loop is twice as fast as the next-best alternative, MVP / MVN. Even if we incur the one-cycle penalty mentioned in my last post we still have a bulk speed of 3.5 cycles per byte. And there needn't be a length limitation of 256 bytes; the inner loop could be called repeatedly. Hmm, looks like I've almost talked myself into coding the routine! But if anyone else wants to give it a go, please do.
Luck will usually be enough! :P But if the interrupt happens to arrive just as the block move ends then you'll overrun the destination buffer. If allowing interrupts is a priority you could perhaps pad the destination buffer to allow a little extra space.
Edit: besides allowing extra space, another option is to always use MVN to move the last few bytes.
