It is currently Tue Oct 01, 2024 4:03 am
PostPosted: Thu Mar 02, 2006 11:22 pm
I got bored. So I started browsing the net randomly, and happened upon 6502.org's source listing for PRIMM. Here are yet more implementations, this time including a version for the 65816 as well. Note that these are untested, and serve more as intellectual entertainment for me.
; Yet more PRIMM implementations (albeit UNTESTED at this point).
; This one has the advantage of not requiring so much zero-page access,
; and therefore results in faster output.
DPL = $xx
DPH = DPL+1
;Put the string following in-line until a NULL out to the console
PRIMM:
        pla         ; Get the low part of "return" address
                                ; (data start address)
        sta     DPL
        pla
        sta     DPH             ; Get the high part of "return" address
        ldy     #1              ; Note: actually we're pointing one short
PRMORE: lda     (DPL),y         ; Get the next string character
        beq     PRDONE          ; break loop when done
        jsr     CHROUT          ; send data to output device
        iny                     ; update the pointer
        bne     PRMORE          ; if not, we're pointing to next character
        inc     DPH             ; account for page crossing
        jmp     PRMORE
PRDONE: iny                     ; Advance beyond NUL byte
        bne     PRD1            ; page crossing overhead
        inc     DPH
PRD1:   iny                     ; Account for JSR's negative bias
        bne     PRD2
        inc     DPH
PRD2:   tya
        clc
        adc     DPL
        sta     DPL
        lda     DPH
        adc     #$00
        sta     DPH
        jmp     (DPH)
; PRIMM for the 65816 16-bit native mode interface
; Assumes 16-bit registers on entry.
; String must (a) never cross a bank boundary, (b) be shorter
; than 65534 characters, and (c) must be NUL-terminated.
; Labels have L_ prefix for routines that are accessed with the JSL
; instruction; S_ for normal JSR instructions (Long vs. Short addresses).
DPB = DPH+1
L_PrImm:
    php
    phb
    sep #P_M        ; Switch accumulator size to 8 bits.
    lda 5,s         ; Set data bank to the caller's code bank
    pha
    plb
    ldy #$0001
L_more:
    lda (3,s),y
    beq L_done
    jsr S_CharOut   ; The 65816-native version of CHROUT.
    iny
    bra L_more
L_done:
    rep #P_M        ; Switch back to 16-bit accumulator
    iny
    clc
    tya
    adc 3,s
    sta 3,s
    plb
    plp
    rtl
PostPosted: Fri Mar 10, 2006 3:13 am
The strings CAN cross bank boundaries, since (3,S),Y can cross the Bank B (i.e. the DBR register) boundary. (However, the 3,S portion of that is taken from Bank 0 -- i.e. the bank where the stack is located -- and it does wrap at the bank 0 boundary. It's kind of like LDA ($FF),Y on the 6502 and 65C02 -- the $FF part wraps on page zero, since the high byte of the pointer is at $00, not $100, but the ,Y part can cross pages.) For example:
PEA #$1212
PLB
PLB
PEA #$FFFF
LDY #1
LDA (1,S),Y
Is like LDA $130000 (i.e. bank $13) rather than LDA $120000.
PostPosted: Mon Aug 06, 2007 7:37 pm
You had the right idea for the 6502 code (saving on zero page access), but it does have a couple bugs. First, Y is incremented one too many times after the null is reached, and the relative JMP uses the wrong target (DPH instead of DPL).
Here is a corrected version, which should indeed be faster on the inner loop than the Ross Archer version in the code repository:
;DPL can be any zero page location except $FF (obviously)
DPL = $xx
DPH = DPL+1
PRIMM:
        sta     DPL
        pla                     ; Get the high part of "return" address
        sta     DPH
        ldy     #1              ; Account for return address offset
        beq     PRDONE          ; don't print the final NULL
        jsr     CHAROUT         ; write it out
        iny
        bne     PRMORE          ; back around
        inc     DPH
        bne     PRMORE          ; if high byte wraps, it'd be trouble
PRDONE: tya
        sec                     ; intentionally set carry (add 1 to skip null)
        adc     DPL
        sta     DPL
        bcc     PRD1
PRD1:   jmp     (DPL)           ; return to byte following final NULL
PostPosted: Mon Aug 06, 2007 9:07 pm
My code advances beyond the NUL byte of the string. So far as I can tell, yours does not. This is why Y is off-by-1 from your point of view. However, your solution uses SEC to get a free "+1" on the address fixup addition, so the end result should be the same.
PostPosted: Mon Aug 06, 2007 9:51 pm
I'll play.
Why fix it at all? why not just keep the low byte in Y,
push the address back on the stack and return?
PRIMM:
        tay                     ; (data start address)
        sta     DPH             ; (data start address)
        lda     #00
        sta     DPL
PRMORE:
        iny                     ; Note: actually we're pointing one short
        bne     OUT             ; first pass here fixes that
        inc
OUT:
        jmp     PRMORE
PRDONE:
        lda     DPH
        pha
        tya
        pha
        rts
(no, I didn't test it to see if it actually works) ;)
note that you only cross the page boundary once
(for each page crossing) this way. (lda(DPL),y will always be 5 cycles)
PostPosted: Mon Aug 06, 2007 10:02 pm
ack!
PRMORE:
        inc
left out a label
PRIMM:
        lda     #00
        sta     DPL
PRMORE:
        inc     DPH
OUT:
        jmp     PRMORE
PRDONE:
        lda     DPH
        pha
        tya
        pha
        rts
PostPosted: Tue Aug 07, 2007 3:23 am
Let's trace the code on an example call with a null string:
$1000 JSR PRIMM
$1003 .BYTE 0
$1004 <- execution should resume here
   ; [JSR pushes return address - 1]
PRIMM:
        pla                     ; [A = $02]
        sta     DPL             ; [DPL = $02]
        pla                     ; [A = $10]
        sta     DPH             ; [DPL = $10]
        ; [pointer at DPL is now $1002]
        ldy     #1              ; [Y = $01]
PRMORE: lda     (DPL),y
        ; [$1002 + Y (1) = $1003, the null byte]
        beq     PRDONE          ; [branches]
        jsr     CHROUT
        iny
        bne     PRMORE
        inc     DPH
        jmp     PRMORE
PRDONE: iny                     ; [Y is now $02]
        bne     PRD1
        inc     DPH
PRD1:   iny                     ; [Y is now $03]
        bne     PRD2
        inc     DPH
PRD2:   tya                     ; [A is now $03]
        clc
        adc     DPL             ; [$03 + $02 = $05]
        sta     DPL             ; [DPL is now $05]
        lda     DPH
        adc     #$00
        sta     DPH             ; [DPH is still $10]
        ; [pointer at DPL is now $1005]
        jmp     (DPL)
Thus, where execution should have resumed at $1004, it jumps to $1005 instead. If you follow the code through on any string, the result is the same.
PostPosted: Tue Aug 07, 2007 3:44 am
<snip>
That's a good solution; it's faster and uses fewer bytes of code. Well done, bogax.
PostPosted: Tue Aug 07, 2007 4:26 am
AH HA, I see what you're saying now. Whoops.
Users browsing this forum: Google [Bot] and 2 guests
