This is most of an answer to Ed's question of command reading and decoding...
It's an interesting subject, one that can quickly lead down many rabbit holes if you're not careful.... However here is my solution - it's working on my Ruby system right now.
First, a demo of it actually running:
Ruby 6502 - Boot 1.2. GO
Ruby OS 64K
* help
Builtin commands:
d
fill
fx
go
help
* d e000 e0ff
E000: D8 78 A2 FF 9A A9 FF 8D | x |
E008: 30 FE A9 81 8D 10 FE 20 | 0 |
E010: 84 E3 20 46 E7 20 AA FF | F |
E018: 0D 0A 52 75 62 79 20 4F | Ruby O |
E020: 53 20 36 34 4B 0D 0A 0A | S 64K |
E028: 00 20 AA FF 2A 20 00 20 | * |
E030: 98 FF C0 01 F0 F3 A0 FF | |
E038: C8 B1 F8 C9 20 F0 F9 C9 | |
E040: 2A F0 F5 C9 0D F0 E2 C9 | * |
E048: 23 F0 DE 20 77 E2 20 AD | # w |
E050: E2 C9 0D F0 D4 A2 00 64 | d |
E058: F2 5A B1 F8 F0 09 DD B1 | Z |
E060: E0 D0 25 E8 C8 80 F3 BD | % |
E068: B1 E0 D0 1C 7A A5 F2 0A | z |
E070: A8 B9 C4 E0 8D 85 E0 C8 | |
E078: B9 C4 E0 8D 86 E0 20 84 | |
E080: E0 4C 29 E0 4C DE E1 E8 | L) L |
E088: BD B1 E0 D0 FA E8 BD B1 | |
E090: E0 F0 06 7A 5A E6 F2 80 | zZ |
E098: C1 20 AA FF 55 6E 6B 6E | Unkn |
E0A0: 6F 77 6E 20 63 6F 6D 6D | own comm |
E0A8: 61 6E 64 0D 0A 00 4C 29 | and L) |
E0B0: E0 64 00 66 69 6C 6C 00 | d fill |
E0B8: 66 78 00 67 6F 00 68 65 | fx go he |
E0C0: 6C 70 00 00 DE E1 8C E1 | lp |
E0C8: E2 E0 6D E1 37 E1 20 AA | m 7 |
E0D0: FF 46 61 69 6C 6C 65 64 | Failled |
E0D8: 20 61 67 61 69 6E 0D 0A | again |
E0E0: 00 60 20 AD E2 C9 0D F0 | ` |
E0E8: 35 20 B1 EA 8D 1B E1 9C | 5 |
E0F0: 1C E1 9C 1D E1 20 AD E2 | |
E0F8: C9 0D F0 13 20 B1 EA 8D | |
* fill 0
Fill RAM with $00 ...
Ruby OS 64K
* go 1000
-> $1000
[BRK 1001:00]
* fx 0
[BRK EED1:00] Ruby 6502 2.0
* help
Builtin commands:
d
fill
fx
go
help
The prompt is "star space" because that's what I prefer. Leading spaces and stars are ignored and '#' is a comment line. I'd also go as far as to suggest that Ruby has an operating system rather than a "monitor" as such. That's my aim, anyway.
The help command just lists the commands, but (soon) it will also scan for a BBC Micro style ROM image and dump that, if present.
'd' is a simple memory dump, 'fill' fills the whole of RAM apart from what the OS runs in. 'go' - jumps to an address. So above, I dumped some RAM, (part of the OS which lives in $E000-$FDFF), filled RAM with zeros, jumped to $1000 which promptly sat on a BRK instruction, then ran another command familiar to BBC Micro users.
I'll list the code in bits rather then a big blob - mostly because it's split over several files, but also so I can put in additional comments...
First the main-loop of the command interpreter:
;* Main Ruby command interpreter
jsr strout
.byte 13,10,"Ruby OS 64K",13,10,10,0
rubyOsCmd:
jsr strout
.asciiz "* "
jsr getline
cpy #1 ; Just one character (CR) ?
beq rubyOsCmd
; Skip leading spaces and/or stars
ldy #$FF
: iny
lda (b0),y
cmp #KEY_SPACE
beq :-
cmp #'*'
beq :-
; Newline?
cmp #KEY_CR
beq rubyOsCmd
; # for comment?
cmp #'#'
beq rubyOsCmd
We need to dive a bit deeper here - the strout and getline functions. I'll leave strout, but getline does this:
; getline:
; Handy short-cut to osWord 0 with fixed parameters for command
; line entry in Ruby OS.
.proc _getline
ldx #<_getlineData
ldy #>_getlineData
lda #0
jmp osWord
_getlineData:
.word $0300 ; Address of input buffer
.byte 250 ; Max length
.byte 32 ; Smallest value to accept
.byte 126 ; largest...
.endproc
That's going to be alien to some - it calls an operating system routine called osWord - and osWord 0 is "read in a line of text with simple editing". I could go deeper, but I'll leave it at that. Suffice to say that the input line will be placed at $0300, max. 250 characters long, and it will accept characters between space and ~. Simple editing is DEL/BS and Ctrl-U to kill the line. There is a zero-page pointer (b0) which is set to the start address which subsequent code relies on. It returns with the length in Y.
Next is the code to start to parse the command-line:
; We appear to have something, so ...
jsr setupArgs
; Get first arg. which is command name
jsr getArg
cmp #KEY_CR ; Shouldn't get this, but...
beq rubyOsCmd
The function 'setupArgs' does some initialisation with the command-line (pointed to by (b0),y) and getArg isolates the next argument/token on the command line. It leaves (b0),y pointing to a zero terminated string, or returns CR in A if there is no-more data on the input line. The very first one should always return something because we check for that in the code above, but it's generic and callable from elsewhere.
The next few lines searches the command table for what we've typed and jumps to code to handle it:
; find command
ldx #0 ; Index into command table
stz cmdI
phy ; Y is index in to argument list
findCommand:
lda (b0),y ; Get character of argument
beq found ; ... Zero is end
cmp commandTable,x
bne nextCommand ; No match - go to next command
inx
iny
bra findCommand
; found - we've gotten to the end of the typed command, make sure the
; command-list is also at it's end too...
found:
lda commandTable,x ; Means argument is < length of keyword, but match.
bne nextCommand ; e.g. we type fi which matches fill...
ply ; Remove/dump search index
lda cmdI ; Get command index
asl a ; Double to index into jump table
tay
lda commandList,y
sta wooly+1
iny
lda commandList,y
sta wooly+2
jsr wooly ; JSR to the command and hope for an RTS
jmp rubyOsCmd
; The wooly jumper
wooly: jmp $FFFF ; Modified
Nearly there, just the code to move to the next command in the command table:
; nextCommand:
; scan through the command table to find the start of the next one
nextCommand0:
inx
; Start by skipping to the end of the one we're currently testing against
nextCommand:
lda commandTable,x
bne nextCommand0
inx ; Skip over the zero
lda commandTable,x ; Check for another zero
beq badCommand
ply ; Reset argument pointer
phy
inc cmdI
bra findCommand
badCommand:
jsr strout
.byte "Unknown command",13,10,0
jmp rubyOsCmd
and finally here, the command table looks like:
; Command table
commandTable:
.asciiz "d"
.asciiz "fill"
.asciiz "fx"
.asciiz "go"
.asciiz "help"
.byte 0
commandList:
.word dump
.word fill
.word fx
.word go
.word help
A command example: The fx command which can take 1, 2 or 3 arguments: (this will be somewhat alien if you've no experience of the BBC Micro)
; fx:
; Call osByte from the keyboard.
; Expects 1, 2 or 3 parameters for the A, X and Y registers
fx:
; Get first argument
jsr getArg
cmp #KEY_CR
beq noparam
jsr atoi8
sta fxA
; Optional 2nd & 3rd
stz fxX
stz fxY
jsr getArg
cmp #KEY_CR
beq doFx
jsr atoi8
sta fxX
jsr getArg
cmp #KEY_CR
beq doFx
jsr atoi8
sta fxY
doFx:
lda fxA
ldx fxX
ldy fxY
jmp osByte
fxA: .byte 0
fxX: .byte 0
fxY: .byte 0
noparam:
jsr strout
.byte "Parameter expected",13,10,0
rts
to fill in one gap, atoi8 converts the argument (b0),y into an 8-bit number. Decimal by default, but $ for hex or % for binary.
so it all seems to work and it's a nice little framework I'm building up the operating system with - which more and more is becoming BBC Micro-like every day. This was not my initial intention, but it's lead on from a simple "how hard can it be" when I was thinking about BBC BASIC. Ah well.
