It is currently Sat Oct 05, 2024 6:46 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jul 07, 2007 4:42 pm
My Kestrel emulator defines a graphics architecture which is capable of displaying bitmaps only -- no text mode at all. Therefore, my character set uses a font which is row-major, not column-major, already.
You can fetch a copy of this character set here if you want:
http://www.falvotech.com/content/kestre ... o/font.bin
PostPosted: Mon Jul 09, 2007 3:59 pm
Hi again,
I'm getting an error when trying to execute
lda(pointerlo),y
it tells me that "Indirect postindexed addressing mode requires byte operand"
Maybe Garth was right afterall....???
loop
 lda (pointerlo),y    ;  here's your indirect indexed adressing
 sta lcd
 iny
 cpy #$08             ; the last byte of character data is the 7th,
 bne loop             ; did we just pass it? if not go back and
                      ; get another byte of character data
PostPosted: Mon Jul 09, 2007 4:16 pm
Indirect addresses with indexing must appear in direct page (aka zero page for 6502 systems).
PostPosted: Mon Jul 09, 2007 4:28 pm
I'm using byte FE and FF of ZP for the pointers... ??
PostPosted: Mon Jul 09, 2007 5:17 pm
How is pointerlo defined?
In some assemblers, if you use this:
pointerlo = $00FE
it will still attempt to treat any use of it as a 16-bit absolute address. If this is the case, try changing it to just:
pointerlo = $FE
Such assemblers should then recognize it as a simple byte-sized operand.
I don't know why or how this convention started (it dates back at least to the late 70s, since Commodore PET assemblers tended to behave this way too). It is very annoying.
PostPosted: Mon Jul 09, 2007 5:35 pm
What's in the assembled code? The line should say
B1 FE
(I double checked this time with WDC's programming manual instead of the book I knew had an error and used anyway before :oops: ) It's strange that you would say, "I'm getting an error when trying to execute". Is this with a simulator? Or do you mean "when trying to assemble"?
PostPosted: Mon Jul 09, 2007 6:11 pm
Yes, I meant assemble... sorry.... using terms from the old BASIC days....
My problem was a stupid one... I was specifiying the value in decimal instead of hex.... duh....
$254 instead of $FE
Sorry....
PostPosted: Tue Jul 10, 2007 3:33 pm
Just thought I would let everyone know that "bogax" code worked great, and I find it simple, and straight forward.
Thanks a bunch.
