Hello hello,
I'm somewhat back, I've been the worst at updating things on here. I've been away for a year and I didn't have what I needed to keep going with this, but now that's not the case
So, I've mostly worked on programming and I'm still not very good, Being more efficient at what it does is something that needs to be improved, but the more I learn the more versatile this thing is getting. I've managed to somehow figure out on how to use shift registers and now I have a lot more outputs to work with. I get a lot of instability with Flash memory so I switched back to using Eproms. Which takes a lot longer to work with. (Maybe I sound like I'm impatient, who knows).
Currently I'd like to redesign the board and make something I can mount in something and take it where I need to. With a few additions and also fix the tiny messes I had to patch in the first board. Most are mechanical improvement, but I want to have a 6551, I've got a few.
Just an update.
-Thank you
