6502 MIDI file player
Re: 6502 MIDI file player
Well that took me some effort! First I replaced the SC26C92 with the SC28L92. In order to make use of the 16 bit FIFO, I had to enable it by setting the MR0A[3] bit to ‘1’. This made no difference in playback performance.
Then I implemented a circular 256 byte software buffer together with interrupt based writing to the UART. That was indeed a bit fiddly because of the distinction between the UART and TIMER interrupts. Eventually I got it sort of working. The MIDI file is playing exactly as before, including the lag at those specific areas, but it also misses several MIDI events which of course is even less desirable. I suspect my mistake is that I’m not clearing the interrupt status register bit that indicates the UART interrupt because I don’t know if or how I have to disable it. (I don’t think I have to clear it, because it’s cleared automatically when reading the interrupt status register?)
I’m using the title music of the game Duke Nukem 3D, which is a standard MIDI file from the 90’s, specifically arranged to be played on a Roland Sound Canvas. On a PC, playing that MIDI file over a conventional MIDI interface with a 5-pin MIDI cable, it plays without any lag. It even plays perfectly after setting the tempo to 250 BPM. That should prove that the MIDI file isn’t hogging a physical PC MIDI interface nor the MIDI synthesizer itself.
I’ve analyzed the MIDI file with an event viewer and the moment my player starts to lag is when various MIDI events are to be played at the same time, i.e. when their delta times are 0. After that, when events are streamed with delta times other than 0, it resumes playing at normal speed.
What I will do next is to 1) change the delta times in those areas to 1, eliminating the fact that they have to be send in one interrupt cycle. 2) Replace frequently used subroutines with macros to speed up the code. 3) Perform some code optimizations suggested previously.
Marco
Perhaps we should take a look at your code.
OK, this is the interrupt code:
I’ve also appended the whole source, it’s too long to put it in the post.
interrupt
pha
phx
phy
lda isr
and #%00001000 ;check if interrupt is caused by C/T
beq HandleUart ;no? goto uart irq
HandleTimer
lda tc ;is binvlq = tc?
cmp binvlq
bne IncTc ;no, increment tc and end irq
lda tc+1
cmp binvlq+1
bne IncTc
lda tc+2
cmp binvlq+2
bne IncTc
lda tc+3
cmp binvlq+3
bne IncTc
ExEv jsr DecodeEvent ;yes, decode a track event (midi/sysex/meta)
jsr GetVarLength ;get variable length quantity
lda binvlq ;is binvlq zero?
ora binvlq+1 ;no, reset tc and end irq
ora binvlq+2
ora binvlq+3
bne ResetTickCounter
bra ExEv
IncTc
inc tc ;increment tick counter tc
bne +
inc tc+1
+ bne +
inc tc+2
+ bne +
inc tc+3
bra EndTimerIrq
ResetTickCounter
stz tc ;Reset Tick Counter tc and end irq
stz tc+1
stz tc+2
stz tc+3
EndTimerIrq
jsr buf_dif ;are there bytes to send?
beq ClearCountReady ;no, exit
lda imr
ora #%00010000 ;enable transmitter TxEMT interrupt according to FIFO level in mr0b
sta imr
ClearCountReady
lda rop12 ;clear counter ready interrupt status bit
ply
plx
pla
rti
HandleUart
lda isr
and #%00010000 ;check if interrupt is caused by transmitter buffer empty
beq EndIrq ;no? exit irq
- jsr buf_dif ;are there bytes to send?
beq + ;no, disable TxEMT interrupt, exit
jsr rd_buf ;read next character to send
sta txfifob ;put character to port
lda srb ;get status reg B
and #%00000010 ;is transmit buffer full?
bne EndIrq ;yes, exit
bra -
lda imr
and #%11101111 ;disable transmitter TxEMT interrupt according to FIFO level in mr0b
sta imr
EndIrq
ply
plx
pla
rti
Marco
I can see one potential problem: The interrupt mask register on your UART is not a read-modify-write register, but write-only; it shares its address with the interrupt status register, which is read-only. So when this code is executed, the timer interrupt will be masked unless it has already fired and not been reset. In practice you are only resetting that interrupt after this code, but it's still bad practice. You should be resetting the timer interrupt very soon after entering the timer ISR, and certainly before unmasking the CPU interrupt (for the "better timer").
To solve this properly, you need to keep a shadow copy of the IMR somewhere. One possibility is to use the "uncommitted" UART register (ureg) at offset $C, which effectively acts as a byte of RAM. The above would then become: …and similarly for disabling the interrupt later.
That MIDI events are lost indicates that your send buffer is overrunning itself. To guard against that, you need to put a check in your midiout routine for the tail pointer becoming equal to the head pointer. To begin with you could make that an abort condition (busy-loop) so that you become aware of the first time it occurs. With the "better timer" routines I suggested, you would be filling the buffer concurrently with the UART handler draining it, so you could simply busy-wait until space appears in the buffer. I would therefore suggest modifying your buffer routines as follows:
lda imr
sta imr
lda ureg
sta ureg
sta imr
init_buf: stz rd_ptr ;setting wr_ptr equal to rd_ptr initializes
stz wr_ptr ;the buffer, showing it to be empty.
rts
midiout: ldx wr_ptr ;start with a containing the byte to put in the buffer.
sta buffer,x ;get the pointer value and store the data where it says,
inx
- cpx rd_ptr ;wait for space in the buffer,
beq -
stx wr_ptr ;then increment the pointer for the next write.
rts
rd_buf: ldx rd_ptr ;ends with a containing the byte just read from buffer.
lda buffer,x ;get the pointer value and read the data it points to.
inc rd_ptr ;then increment the pointer for the next read.
rts
buf_empty: lda wr_ptr
cmp rd_ptr ;ends with Z set if the buffer is empty.
rts
rd_ptr !byte 0 ;reserve one byte of ram for the read pointer
wr_ptr !byte 0 ;and one for the write pointer.
- BigDumbDinosaur
Turning the TxD IRQ on and off during run time is not a recommended procedure. Instead you should disable the transmitter when there is nothing to transmit and re-enable it when data to transmit becomes available. Disabling the transmitter will automatically cancel a pending TxD IRQ, and is accomplished with a single write to the channel command register—also the case when re-enabling the transmitter. I've given you working code in the past, Marco, on how to correctly handle this stuff—you should refer to it to avoid having to re-invent the wheel.
As for the timer, reading the ISR to determine if the timer is responsible for an IRQ only tells if that is the case. It doesn't cancel the IRQ. A timer IRQ is cleared by issuing a "stop timer" command. If the timer is in free-run mode it continues to run despite the "stop timer" command.
Lastly, subroutines in interrupt service handlers are not advisable. Unless there is a really compelling reason to use a subroutine, all ISR code should be linear to avoid the stack activity required with subroutines.
Last edited by BigDumbDinosaur on Fri Jan 18, 2019 7:37 am, edited 1 time in total.
I suspect he's trying to learn by doing, rather than by following a recipe. In context, I don't think subroutines or the precise method by which interrupts are turned off are that big a deal.
But yes, he needs to move the timer IRQ reset much earlier in the routine. That in itself should give him some more margin.
- BigDumbDinosaur
As for subroutine usage, when the interrupt rate starts getting up there, the additional cycles represented by a JSR/RTS pair become significant. In my 65C816 interrupt processing article, I noted the following:
- The use of subroutines in an interrupt service routine can substantially hurt performance, as each JSR – RTS pair will consume 12 clock cycles, or 14 cycles if using JSL – RTL. If your interrupt handler includes three calls to the same subroutine and is processing a 100 Hz jiffy interrupt, 3600 clock cycles will be consumed per second just in executing JSR and RTS instructions. A lot of foreground processing can be completed in 3600 cycles! Only use subroutines if you have to squeeze every last byte out of the available address space.
Can be, I'll grant you. But I don't think @lordbubsy is at the level of worrying about that just yet; those are optimisations he can make in due course.
@Chromatix
Indeed I am. I just began writing this MIDI player by reading the MIDI implementation. It worked out very quickly and very well, but I must admit that I have a hard time to make sense of what happens when the code in the interrupt routine takes more time than it’s given for one interrupt period. Especially when there is more than one interrupt involved.
OK, that’s what BDD also said about the MRxx registers, I just have forgotten to implement it. However, that made no difference. It still loses events and stalls.
Done that.
I tried your suggestion but it made no difference, events still got lost. So I tried this to stop the program if the buffer would get full.
...but it doesn’t stop, so the buffer isn’t overrun???
I suspect that my UART interrupt routine is not functioning well in conjunction with the timer routine.
I think I’ll revisit the "better timer" routines you suggested, because I haven’t implemented or even understood them.
@BDD
I replaced the TxD IRQ on and off with disabling / enabling the transmitter with:
Unfortunately no change.
Yes you did, but back then I got it working on MARC-2 by copy and paste. A few months back I tried to get it working on MARC-4 but I failed. Perhaps I should give it another try. I’m rather new to the interrupt thing, I got several things working on a VIA handshake interrupt, the VDP scanline interrupt and the DUART timer interrupt. But I’ve still got to figure out the UART interrupt a bit more.
As far as I know I’m doing that by reading register “duart_base + $f”, right?
That’s definitely an easy thing to do next, but I don’t think it will save the day.
Here is how I initialize the timer and UART interrupt:
Initialize the MIDI UART channel B:
Setup the interrupts:
The interrupt routine itself:
Thanks for all the patience, I hope it isn’t getting too boring.
The interrupt mask register on your UART is not a read-modify-write register...
inx
beq +
rts
+ stp
@BDD
lda #%00000101 ;enable Tx enable Rx
sta crb
lda #%00001010 ;disable Tx disable Rx
sta crb
acia_b_init
lda #%10110000 ;set MR pointer to 0
sta crb
lda #%00000000 ;MR0 Normal mode
sta mr0b
lda #%00010011 ;No parity, 8 bits per char.
sta mr1b
lda #%00001111 ;Stop bit length 2.000
sta mr2b
lda #%11101110 ;receiver clock select IP5-16X transmitter clock select IP5-16X
sta csrb
sta crb
rts
SetupDUARTInterrupt
sei ;disable interrupts
lda #<interrupt ;set interrupt vector
sta $fffe ;RAM on MARC-4
lda #>interrupt
sta $ffff
lda #>$1000 ;set c/t for 192Hz or 5208us
sta ctpu
lda #<$1000 ;deviser = 3.6864MHz / (2*192) = 9600 = $2580
sta ctpl
lda #%01100000 ;enable timer (square wave) X1 mode
sta acr ;clear bit 4 and set bits 6 & 5
lda #%10110000 ;set MRB pointer to 0
sta crb
lda #%00000000 ;MR0[5] MR0[4] Transmitter FIFO Interrupt Fill Level
sta mr0b ;8 bytes empty TxEMPTY
lda #%00011000 ;enable counter ready interrupt and transmitter interrupt
sta imr
lda sop12 ;start timer by reading register 14
cli ;enable interrupts
rts
interrupt
pha
phx
phy
lda isr
and #%00010000 ;check if interrupt is caused by C/T
beq HandleTimer ;no? goto uart irq
jmp HandleUart
HandleTimer
cmp binvlq
lda tc+1
cmp binvlq+1
bne IncTc
lda tc+2
cmp binvlq+2
bne IncTc
lda tc+3
cmp binvlq+3
bne IncTc
ora binvlq+2
ora binvlq+3
bra ExEv
IncTc
bne +
inc tc+1
+ bne +
inc tc+2
+ bne +
inc tc+3
bra EndTimerIrq
ResetTickCounter
stz tc+1
stz tc+2
stz tc+3
EndTimerIrq
sta crb
ClearCountReady
ply
plx
pla
rti
HandleUart
lda isr
bra -
lda #%00001010 ;disable Tx enable Rx
sta crb
EndIrq
ply
plx
pla
rti
Marco
If x or y is not needed on the interrupt handler then there is no need to stack them.
The HandleUart code can be before the interrupt handler then you wouldn't need the Jmp.
Instead of AND for checking bits, you can use BIT. This doesn't destroy contents of A.
bit #%00000100 ;is transmit buffer ready?
beq EndIrq ;no, exit
@Chromatix
Thank you! It’s working now, that is, the MIDI file is playing back as previously. All events are being send, but there where’re multiple events with delta time 0, it starts stalling. i.e. the player behaves as if there were no software buffer or transmitter interrupt.
I’m not sure if I said this before, but the tempo restores to normal when the MIDI stream is less busy. What I didn’t notice until now is that there is a difference in playback speed during those stalls while playing them back with 8MHz or 1MHz.
Could it be that a PC MIDI interface is better in handling those dense MIDI streams?
There is also something called intelligent mode, which I haven’t implemented.
@BDD
I’m trying to figure out the SC26C92 routines you gave me years ago. It’s going slowly...
@BDD
Marco
In all honesty, this is good practice for me as well. It might even give me an excuse to get interrupts and some devices working in my emulator. Perhaps you could upload the code as it presently stands, as its misbehaviour would be a good test case for emulation.
I recall previously you said the tempo didn't vary with CPU speed, so I think we're making progress, in that the bottleneck has moved. That means we've solved one problem and uncovered another. Previously the UART was blocking progress, now we're simply taking too long to process each flood of MIDI events in software. The outcome is similar; we miss timer interrupts, so the beat slows.
The solution will probably be that "better timer" I described previously. Implementing that correctly will require a relatively deep understanding of how interrupts really work on the 6502, but it will then count the number of missed timer interrupts, and allow the MIDI routine to catch up once it's finished processing the current tick.
Optimising your code is also likely to help, but only on the quantitative level (like increasing the CPU speed), not qualitative (avoiding perceptible slowdowns entirely). The PC benefits here from having a vastly more powerful CPU, but that is overkill for the simple task of decoding a MIDI file, and much of the extra power is absorbed by increasingly inefficient layers of "modern" software. There are, however, one or two hints at reasonable optimisations in the pseudocode I posted earlier, such as counting down from the delta value to zero, instead of counting up to it from zero. This means you can perform the test against reaching the deadline more efficiently. This is a standard transformation that you can often apply in low-level coding, and which compilers often apply behind the scenes.
As it happens, while counting down a single-byte variable to zero is easy and fast on the 6502, for multi-byte variables it's more efficient to bitwise-invert the value and then count up to zero. Consider this variant on your main loop:
HandleTimer
; insert mutex test etc here
IncTc
inc tc ; increment tick counter tc and test against zero
bne EndTimerIrq
inc tc+1
bne EndTimerIrq
inc tc+2
bne EndTimerIrq
inc tc+3
bne EndTimerIrq
ExEv
jsr DecodeEvent ; decode a track event (midi/sysex/meta)
jsr GetVarLength ; get variable length quantity
lda binvlq ; is binvlq (delta ticks) zero?
ora binvlq+1
ora binvlq+2
ora binvlq+3
beq ExEv
lda binvlq ; transform binvlq into count-up-to-zero form
eor #$FF
sta tc
lda binvlq+1
eor #$FF
sta tc+1
lda binvlq+2
eor #$FF
sta tc+2
lda binvlq+3
eor #$FF
sta tc+3
bra IncTc ; complete the negation by incrementing it
- BigDumbDinosaur
lordbubsy wrote:
@BDD
