The '816 uses an 8-bit register (DBR) to select the data bank which can be modified by pulling from stack with a PLB instruction. The simplest way to change bank is ..
lda #BANK(xx)
pha
plb
.. but this will only work correctly if A is in 8-bit mode. In 16-bit mode it will leave a byte on the stack. You can change the register size to make it always work and restore the size at the end.
php
sep #$20
lda #BANK(xx)
pha
plb
plp
If X register is free then you could save a copy of the stack pointer and use PEA to push the bank on to the stack and use a TSX to restore the stack at the end.
tsx
pea #BANK(xx)
plb
txs
The use of X could be avoided by putting the bank as the second byte on the stack.
pea #BANK(xx)<<8
plb
plb
Another approach would be to install a small subroutine in the data bank consisting of ..
phk
plb
rtl
.. and JSL to it to copy the program bank (PBR) into the DBR.
Any other techniques I've missed?
