It is currently Fri Nov 22, 2024 11:21 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: CPLD 6502
PostPosted: Wed Jan 02, 2019 7:23 pm
Arlet wrote:
Yes. Alternatively, you could instruct the ALU to put a constant on SB, so it will be added to the vector address, maybe to implement a complete interrupt dispatcher.
Thank you.
Arlet wrote:
There's a bug in the code by the way. As you say, 'B' is set in the pushed flags, but it is also set when doing an IRQ. I still need to fix that.
Perhaps you can use IR=00 to set/reset 'B' during push. But I am not familiar with the special situations that (maybe) arise when an IRQ or NMI appears during processing of a BRK instruction. IIRC Drass have had some trouble with spurios interrupts in his TTL approach. Obviously these special situations are not documented - at least as a part of the datasheet.
Regards,
Arne
PostPosted: Wed Jan 02, 2019 7:36 pm
Yeah, I need to recheck all the corner cases for IRQ/BRK/NMI happening at the same time. I'm pretty sure there are still some problems.
PostPosted: Thu Jan 03, 2019 2:10 am
On the subject of (zp) addressing mode, it might be worth looking at it as equivalent to (zp,X) or (zp),Y modes with the index replaced by a zero. I don't know whether that helps…
PostPosted: Thu Jan 03, 2019 7:44 am
Yes, that's how it should be done. Right now, the core only has one combined (ZP,X),Y addressing mode with either X or Y replaced by zero, so it would seem to be a simple extension of that idea. The problem is that the extra opcodes don't really fit in the old pattern, so a fairly large amount of extra control logic is needed.
I'll give it a shot later, but I first want to fix the bugs.
cron
