When I was developing my metacompiler, I added a feature that I never actually needed ( it was easy to add ). The metacompiler has a word SUB which is used to write subroutines a code word might need.
I really shouldn't post when I'm tired. I
do use
SUB in my kernel source. Before that, I used
LABEL ( makes a metacompiler label ) and invoked the assembler directly.
SUB was so much easier.
If it were just a stand alone program that takes a text file and spits out an assembled binary, then it's simply a different syntax rather than an entirely different tool chain.
I made some improvements to my metacompiler. With
INCLUDE , it can take this sequential file from a C64 disk and compile it with no Forth, no headers, just the assembly code. It then prompts for a filename and spits out a binary to the disk. The demo does what some programs meant to be called from
BASIC does, SYS 49152 does one thing and SYS 49155 does another.
HEX START
C000 ORIGIN
SUB TWIN.DEMOS
AHEAD,
0 # LDA, TAX,
10 # LDY,
BEGIN,
D020 STA, CLC, 1 # ADC,
CS-DUP 0= UNTIL, // CONTINUE
INX,
DEY,
0= UNTIL,
RTS,
THEN,
0 # LDY, FC STY,
7 # LDA, FD STA,
4 # LDA, FE STA,
E8 # LDY,
BEGIN,
DEY,
FC )Y LDA, 80 # EOR,
FC )Y STA,
0 # CPY,
FD DEC, FE DEC,
0= UNTIL,
RTS,
END-CODE
TSAVE
