It is currently Sun Sep 29, 2024 3:36 pm
PostPosted: Thu Nov 29, 2018 6:07 pm
I have an embedded 65C02 system developed with an Avocet assembler (X6502.exe).
I want to port this code to a system built around a 65C816.
I've tried the Western Design Center WDC816AS.exe assembler but it fails to complete (i.e., crashes during assembly).
I'm told that Avocet also made an assembler for the 65C816.
I would like to find someone who has such an assembler and user's manual that I might purchase.
Please contact me if you have these.
PostPosted: Thu Nov 29, 2018 10:43 pm
Welcome.
I believe Avocet did have an '816 assembler, but that they're out of business now. They had taken over selling the 2500AD assembler too for a while (without supporting it very well at all), but I removed it from my link page's assembler section when the link went dead. Do you specifically need Avocet, or are you just looking for an assembler that assembles for the '816? I have a list of 65xx (including '816) assemblers at that URL. Most of them are free. I use, and really like, the C32 (Cross-32) assembler for the '816. Actually, for $99, you buy one assembler that works for dozens of processors, so you don't have to buy another one for each. It's a powerful macro assembler. There are a couple of very good ones listed there from our own forum members too.
PostPosted: Fri Nov 30, 2018 9:00 am
I had a issue with spaces in expressions (e.g. "1 + 2" rather than '"1+2") but WDC had a fixed version of the assembler for that.
I've posted several examples on this forum that use my OpenSource Java based assembler package that does 65(C)02 and 65816 (which also does 4004, 4040, 8008, 8080, 6800, 6809, MELPS 740, CDP 1802, SC/MP and shortly KENBAK-1).
Here is an example http://forum.6502.org/viewtopic.php?p=60467#p60467
Andrew Jacobs
PostPosted: Fri Nov 30, 2018 1:04 pm
We use an Avocet assembler for our 65C02 code.
We're trying to use this code as a base for 65C816 follow-on development.
Our thought is that an Avocet assembler for the 65C816 would have similar syntax, etc., and make the porting go smoother.
Supposedly Western Design Center supposedly supports their assembler but it crashes without providing any information regarding the cause.
I'd really like to find an Avocet 65C816 assembler to see where we need to make changes.
PostPosted: Fri Nov 30, 2018 2:05 pm
If I were in your position I'd make at least a superficial attempt to isolate the problem. (Perhaps you've already tried this.) For example, can you successfully assemble a "program" that's just a single instruction (such as a branch to self)? If *that* crashes then you've learned something meaningful.
Or, if it works, try assembling an edited version of your desired source code... a version that has about half of its original content deleted. Obviously there will be error messages, but does it crash? If the crash disappears then that implies some sort of difficulty in the portion you deleted. You could then repeat the experiment again and again with successively smaller portions deleted until the offending content becomes clear... if you have the patience, that is. And there's a risk this could turn out to be a waste of time.
Have you tried contacting Western Design Center?
cheers
PostPosted: Fri Nov 30, 2018 2:15 pm
We've done what you suggest.
As we successively partition the code down to smaller chunks we continue to receive 'crashes' with no indications as to why the crash occurs.
The final partition is the trivial one where no code is included.
At that point there's nothing to be learned.
We've been in contact with Western Design Center.
PostPosted: Fri Nov 30, 2018 2:25 pm
It crashes with no code included? THAT is something significant you've learned.
Curious to hear how this plays out with WDC. Keep us posted, please.
PostPosted: Fri Nov 30, 2018 2:39 pm
Maybe I haven't been clear.
The Avocet 2500AD X6502 assembler is the one we have used successfully for years.
In our effort to port to the 65C816 we've been trying to use the Western Design Center WDC816AS.exe assembler on our code base.
It's the WDC816AS.exe that crashes on all but the most trivial partition of our code base.
Our thought is to try an Avocet assembler for the 65C816, if it exists.
In the future the plan is to rewrite portions in C but for the time being we want to get the existing embedded system functioning on the 65C816 device.
PostPosted: Fri Nov 30, 2018 4:04 pm
If you mail me some of you code I could have a try diagnosing the issue for you. Other than the expression syntax issue I've found the WDC assembler to be stable.
Andrew Jacobs
PostPosted: Fri Nov 30, 2018 4:20 pm
Or perhaps I was unclear. What I was asking is how did WDC respond when you contacted them? Do they seem interested in helping?
