You just need enough pins spare on a microcontroller.
Yup. If you have lots of pins available then you can
take over both the 65xx address and data buses, plus a few control signals. It's a very simple scheme to get working but you need to have plenty of microcontroller pins available. In some circumstances it's not easy to provide that many pins, so FWIW I'll quickly mention two alternative solutions that trade off the extreme simplicity for something that's more physically compact and involves less wiring.
This scheme
takes over only the 65xx data bus, plus a few control signals -- ie; not the address bus. Lots of people have come up with this idea, and in many cases it'll be the best tradeoff. The 65xx CPU participates in the bootup by running a simple program which appears to reside in memory but is actually generated by the microcontroller.
This scheme
only takes over three control signals. Again, the 65xx CPU runs code which appears to reside in memory but is actually generated by the microcontroller. Even a tiny 8-pin device is more than sufficient (and as a bonus it manages Reset, too).
