65C51... really depends on which manufacturer and spec you have... plus how you're trying to use the chip, i.e., IRQ-driven or polled, etc. Bill O has had luck running at very high speeds but simply using polled I/O mode...
I have. In doing experiments the propagation delay in enabling the chip is critical - at least for polled use. BTW, I have a large pile (more than 60) of these Intersil CDP65C51A UARTs. I'd be willing to test at high speed (20Mhz) and ship a couple of them out to anyone that would like to try them for free (as long as you pay the shipping)
Faster is not always better.
If you can make it work its is. (I used to race dirt bikes ... so ...)
cbmeeks wrote:
IIRC, I believe the AT28C256 is rated at 150ns.
How fast have you guys pushed ....
I've recently used SST 27SF256 EEPROMs rated a 70ns which I seem to be able to push to 20MHz. I'm really liking the EEPROMS as they greatly speed up the re-programming process. However, I generally use the fastest stuff I can get for anything I build these days. There are DIP EPROMS readily available in 45ns and even 35ns versions. Unfortunately I have no experience with these ATMEL parts.
If you run a cable from a workbench signal generator to the board, you will probably need to terminate it with a resistor matching the characteristic impedance (Zo) of that cable, or you will get reflections buzzing back and forth between the ends of the cable that can keep your board from working.
This is what I do using a cheap (~$150) JDS6600 60MHz DSP based generator. It gets the job done. At least up to 20MHz so far. Keep the unshielded leads short and use termination.
