It is currently Sun Nov 24, 2024 8:37 am
 Post subject: Potpourri6502 is alive!
PostPosted: Wed Oct 17, 2018 2:12 am
So, I finally got the board populated. But before did all of that, I did electrical checks, etc.
At first, I was having a really difficult time getting it to free-run. My final design was to use a 1.0MHz half-can oscillator. If I can run at 1MHz, then I'm happy. But before that, I wanted to slowly ramp up the speed with my function generator and monitor it that way. So I put the FG at 100 Hz, then 100 kHz, etc. but nothing seemed to work. It was flaky. Sometimes it would work, sometimes not. So I think I was doing something wrong with the FG. I had it at a square wave with 5 VPP. So, not sure on that one.
Now, the bad part is that I don't have a 1MHz half-can oscillator. I only have it in a full can. I do have a bunch of 3.58MHz half-can oscillators so I thought what the heck.
I plugged everything in and wrote a simple program to increment the VIA on PORT A (after confirming the free-running NOP program).
I connected some LED's to the PORT A and noticed all solid. Even PA7. Well, stupid me...at 3.58MHz, it was SCREAMING along! So I kept adding long loops and delays! Finally, I settled on this program:
        .debuginfo  +
        .setcpu     "65C02"
        .ORG   $8000
VIA     :=      $6000
PB      :=      VIA
PA      :=      VIA + 1
DDRB    :=      VIA + 2
DDRA    :=      VIA + 3
; reset vector points here
RESET:
        LDA     #$FF
        STA     DDRA
        STA     DDRB
MAIN:
        INC     PA
        LDX     #00
        LDY     #04
LOOP1:
        DEX
        CPX     #00
        BNE     LOOP1
LOOP2:
        DEX
        CPX     #00
        BNE     LOOP2
LOOP3:
        DEX
        CPX     #00
        BNE     LOOP3
LOOP4:
        DEX
        CPX     #00
        BNE     LOOP4
        DEY
        CPY     #00
        BNE     LOOP1
        JMP     MAIN
; system vectors
; (IGNORE THESE..ASSEMBLER ONLY PUTS ZERO SO I MANUALLY EDIT THE VECTORS)
;  I will figure this out later.
        .org $7FFA
        .byte $00,$80,$00,$80,$00,$80
So, after all of those loops, I finally got it slow enough that I can see the lights blink! It's been running solid at 3.58MHz for over an hour. I can't believe it! It actually works first time!!
For grins, I put my oscilloscope on PA0 and as you can see in the pic, I am getting a SOLID 62.5Hz square wave. I mean it's not fluctuating one little bit that I can see. :-D
I'm literally grinning ear to ear with this. This is a long time coming! Thanks to everyone on this board for all of the help.
Now, it's time for some more advanced experiments. My first expansion card is going to be a NXP DUART card so that I can remote in and run some BASIC...
Shoot, if the speed holds steady at 3.58MHz, I might just leave it at that instead of 1MHz like I planned. When everything settles in and I get some more demos going, I will crank the speed up and see what she can do!
BTW, I'm trying to upload a video of it but YouTube is being cranky.
This is SUPPOSED to be the YouTube link but it's not playing for me. For some reason, it rotated the video!! Ugh.
https://youtu.be/hsMCq5HHSic
You will notice a bridged wire instead of a power switch. The reason is that I don't have a power switch handy. LOL
Also, the reset button is the only one I have.
File comment: Populated board
File comment: Blinky lights
File comment: PA0 running at a STABLE 62.5Hz
PostPosted: Wed Oct 17, 2018 3:15 am
Probably means you've overlooked something. :wink:
Just kidding, cbmeeks -- please forgive the dour joke. Congrats on your success!!
PostPosted: Wed Oct 17, 2018 3:53 am
cbmeeks wrote:
So, after all of those loops, I finally got it slow enough that I can see the lights blink! It's been running solid at 3.58MHz for over an hour. I can't believe it! It actually works first time!! <...> I'm literally grinning ear to ear with this.
Makes one feel great, doesn't it?! :D It an energizer.
BTW, in this repeating segment,
        DEX
        CPX     #00
the CPX #0 is redundant. It's an automatic, implied part of the DEX (along with anything else that affects X). Same for the CPY #0 after the DEY. If you really want the extra two cycles' delay, NOP gives it with a single byte.
YouTube stopped working for me this afternoon too. [Edit: It's working again now.] Other video sites work. https://www.real.video/ is a new one that's growing very fast, without the censorship of YouTube. Get a channel, free.
PostPosted: Wed Oct 17, 2018 4:37 am
U-Toobe hasn't been the same since Google got its meathooks into it. Those people are very annoying, to politely put it.
PostPosted: Wed Oct 17, 2018 10:22 am
Contrats! It looks great even sideways.
PostPosted: Wed Oct 17, 2018 12:40 pm
Thanks again for the kind words, everyone.
Hey, no one is more surprised than me that it worked first try. I'm a software developer by trade and I'm used to many iterations until something works. lol
Ah, thanks for the tip.
Yeah, I've been so focused on the hardware side of things that I've neglected my 6502 skills. Which is yet another reason to build this computer and my upcoming "trainer" computer.
In fact, I may shift gears a little bit. I have a nice 20x4 character screen that I want to start programming a monitor for it. Along with a small matrix keypad. So I definitely see some coding questions coming in the near future. :-)
BTW...the ROM situation is already getting annoying. Pulling that chip out with tweezers each time I program it has got to go.
Unfortunately, I only have one ZIF socket of that size and the pins are super fragile and bend easily. But it appears that if I can get it elevated just a little bit...like the height of 1-2 DIP sockets, then it clears everything just fine. So this evening I hope to build a little riser card for it using some WW pins I have.
Another problem I ran into is that my programmer sometimes won't burn my code onto the ROM. I have to remove the chip and re-socket it a couple times and it works. However, I can erase it any time I want. So I'm not sure what that's all about.
PostPosted: Wed Oct 17, 2018 12:55 pm
Congrats, having your first selfbuilt SBC up and running for the first time is a moment you always will remember. :)
Would suggest to go for more expensive connectors and IC sockets when soldering the next SBC.
It's annoying if a piece of technology which perfectly had worked suddenly stops working
because of saving just a little bit of money at the wrong end.
The big electrolytic capacitors are a bit close to the J8..J11 connectors.
If this causes problems when plugging something into these connectors,
one "workaround" would be placing the capacitors at the bottom of the PCB...
About the oscillators:
My trick was to have a 74393 (containing two 4 Bit counters) on the PCB.
Then to use the counters as dividers for the CPU and UART oscillators,
tapping into the counter outputs with jumpers for getting the CPU and UART clock signal.
This way, I didn't need a collection of oscillators for many different frequencies.
An interesting question is, how hot that 7805 is going to get when plugging some PCBs into these connectors.
Maybe it would make sense to check temperature with a thermocouple connected to the 7805 package sometimes.
(some of the multimeters can read thermocouples).
The MIC29300-5.0WT low drop regulator is more expensive than the 7805, but can take quite a beating.
Hmm... maybe some of the "wall warts" have + at the center of the connector, while some others might have GND.
Maybe it would be good to have a diode reversed between Vin and GND of the regulator,
for clobbering down negative voltage at the regulator input (SB560 is cheap nowaday).
If the programmer programs the ROM, but there seems to be a "bit rot" in the ROM after some "minutes",
this usually means that the ROM needs a different "programming algorithm" than the programmer had used...
...please check, if vendor and part number are identical on the chip package and in the programmer settings.
Oh, and try to avoid Google. It's evil. //Everybody is supposed to know this by now.
PostPosted: Wed Oct 17, 2018 1:08 pm
Ouch. I had a look at real.video. What a cesspool. I think I'll stick with u-t.
Anyway, congrats to cbmeeks. It looks good, even sideways as scottws says! :)
PostPosted: Wed Oct 17, 2018 3:09 pm
Oh yeah. I still have my 10 PCB's I made earlier. I keep one on display as a reminder. I use another as a bookmark. LOL.
But this one...this one actually works! So yeah, I will remember this one for a long time.
I totally agree on that one. I normally get connectors from Taydae (http://www.taydaelectronics.com) because they are so cheap. Even the dual-wipe sockets. And, I almost always get them within a week instead of waiting a month or more from China. They are good for cheap, throw away boards I build. However, I plan on using two of these boards in the immediate future. One as a bench PC and the other in a case I want to put on display. So for them I want some good connectors. Do you have any recommendations?
Already caused an issue. LOL
I made a little board to plug into the slot (not pictured). It bumped up against the cap a little so I just cut a notch on the board. I figure when I design a real PCB for expansion slots, I will make it more "L shape" to accommodate large caps. Plus, it will give it that retro-vibe I'm looking for. :-)
That's a good idea. I seriously thought this machine would never run over 1 MHz because I was being a little (a lot??) sloppy in the routing, using 2 layer, etc. I'm genuinely surprised I'm running at 3.58MHz. Anyway, I plan on putting serial on-board of my next computer so I will probably share an oscillator to save space.
sometimes.
I ran it for almost two hours last night and it was barely warm to the touch. I don't have a real heat-sink on it but I do have a screw that goes through the hole and then into the (small) mounting hole. So that's a tiny little bit of metal to sink some heat. If I notice it gets too hot I will do something better. I don't have a thermocoupler at the moment but I do have one of those heat sensor guns I could try. When I mount it in my metal case, I plan on doing something much better like using the case as a giant heat-sink.
Yeah, that's a good idea as well. I may add that on my next revision. I will certainly add it on my next design.
PostPosted: Wed Oct 17, 2018 3:24 pm
The content? Yeah, at first glance it seems to have a far-right slant that I find unpalatable.
Agreed.
PostPosted: Thu Oct 18, 2018 6:16 am
Pedestal for coffee cups.
MPE Garry 115-2-020-0-MTF-XS0.
Fischer Elektronik BL6 025 series.
Fischer Elektronik has some nice nice stuff: heat sinks, casings, etc., but industry grade parts ain't cheap.
BTW: when a PCB trace goes to a connector pin, in my PCB layouts I tend to make the last segment of the trace 32 mil or such,
just to make sure the traces to the connector pins don't get hairline cracks after a lot of connector plugging/unplugging cycles.
Sometimes I also did this with EPROM sockets.
Murata GRM31CR60J227ME11L, ceramic 1206, 220uF 6.3V 2.10€ ? ;)
Hmm... from the ST datasheet, 78xx regulators with >6V output can be damaged when they have a lot of capacitance at the output
while the input is switched to GND, and suggest to add a diode reversed between input and output as a protection.
If you are paranoid that your voltage regulator might be getting damaged during power_off,
you could add something like a 1N4007 to your voltage regulator.
The MIC29300-5.0WT I had mentioned above in the thread costs ca. 3€, has short circuit current protection,
doesn't mind a lot of capacitance at the output, can take -20V input voltage...
and because it's a low drop regulator, in theory it can generate 5V from a 6V input voltage at 3A.
7805 would need more than 8V at the input for generating 5V.
Of course the interesting question is how the output voltage of your "wall wart" goes down when current increases,
and how much AC ripple the "wall wart" has at the output while sourcing the full current.
Another idea would be buying a switchmode power supply like the Meanwell RS-15-5 for ca. 8€.
cbmeeks wrote:
[SB560 diode preventing negative supply voltage]
SMD version of the SB560 would be SK56C.
Also, it would be good to add a TVS diode (transient voltage supressor) against electrostatic discharge between +5V and GND.
BTW: Just taking a look at real.video gives me a headache.
PostPosted: Thu Oct 18, 2018 9:04 am
Well done cbmeeks!
(It would be great if we could resist the temptation to bash one or other corporation - you can see how it derails the conversation. Just make your own choices, and trust that others are also making theirs.)
PostPosted: Fri Oct 19, 2018 12:40 pm
Very cool! Congratulations.
It is indeed a thrill to have something work as planned. Even if it takes a couple of attempts.
PostPosted: Fri Oct 19, 2018 1:43 pm
Congrats on getting a PCB SBC up and running... always gratifying to see your efforts work. You should be able to keep the clock speed up around 4MHz without much issue. I've been running a split PCB setup at 12MHz... using a CPU board with RAM/ROM, decode and a second board with a 65C22 and 65C51, albeit a very short ribbon cable between them.
PostPosted: Fri Oct 19, 2018 1:50 pm
Thanks for the comments!
Yeah, I'm very happy with the board so far. Everything I've tested works well. I think I've settled on running it at 4 MHz. I was happy at 1 MHz but if it can handle 4, then so be it. Makes the math a little easier than the 3.58 MHz it's running now. Just need to get some oscillators ordered.
When I get some more code working, I may try to drive it from my function generator again. It can do 5 MHz. So I'm not sure why it didn't work reliably before. I used to use it all the time to drive some AY-3-8912 sound chips. So I probably just goofed something up.
Users browsing this forum: Google [Bot] and 48 guests
