It is currently Sat Nov 23, 2024 12:31 pm
PostPosted: Thu Aug 30, 2018 6:42 pm
I've seen designs that fully qualify a memory read/write into two separate pins (/MRD and /MWR).
For example, Daryl's SBC 2.5 does this using the R/W and CLK2 inputs. That way, you avoid writing to RAM while O2 is low.
But I was wondering...if using a CPLD for memory decoding, would you still recommend putting read/write into two separate pins? Or, would making a "virtual" R/W pin be good enough?
I was thinking the virtual R/W pin could act like the normal R/W but this one would be controlled by the CPLD. In fact, could you not use a global clock for PH2 and another global clock for R/W? That way, the CPLD would only need one I/O pin for the new R/W.
Thanks for any tips.
PostPosted: Thu Aug 30, 2018 7:06 pm
You could setup your CPLD to do the address decoding, but qualify the ~CE outputs by PHI2. Then the inputs on your RAM (etc) could be arranged ~RE -> Ground, ~WE -> R/~W, assuming that your RAM chip's ~WE overrides ~RE, which in my experience they usually do. This would indeed save you a three pins on your CPLD - since you wouldn't need an R/~W in, nor ~RE & ~WE out.
The main downside is that most RAMs and ROMs i've seen take less time for their output to settle from ~RE/~WE than they do from ~C,E so, depending on your clock speed, it can be advantageous to allow ~CE to go low whilst PHI2 is still low, so that the RAM has maximum time to respond to the ~CE. This means your minimum access time becomes the RE/WE-to-valid time rather than the CE-to-valid time.
PostPosted: Thu Aug 30, 2018 7:10 pm
I used an Atmel ATF22V10CQZ as a single glue logic chip in my last SBC project. It handled address decoding for RAM, EEPROM and 5- 32-byte wide I/O selects... plus qualified /MRD and /MWR signals based on the CPU CLK and R/W as inputs. I used a NXP UART for console/timer, which has separate /RD and /WR signals, so separate signals are requred. I used the same (signals) for RAM, EEPROM (with a write protect jumper) and the UART. I also have these signals on the expansion bus connector for additional I/O devices.
PostPosted: Thu Aug 30, 2018 7:43 pm
Qualifying /CE with Ø2 is not a recommended practice. For best performance, reads and writes should be the only thing qualified with Ø2.
PostPosted: Fri Aug 31, 2018 6:23 am
I did explain that point in the rest of my post, nevertheless it is possible.
PostPosted: Sat Sep 01, 2018 5:11 am
Doing a swan dive off a high voltage tower is possible as well, and also not recommended. :D
cron
