Once a prime is found it should went into DIVS%(J) I assume?
Arne
J%=1
FOR I%=1 TO 2*3*5*7 STEP 2
IF (I% MOD 3)*(I% MOD 5)*(I% MOD 7) THEN WHEEL%(J%)=I% : J%=J%+1
NEXT
100 REM
110 REM B A S I C - B E N C H
120 REM
130 REM The program tests whether it is in the area [3.. a] of the natural
140 REM Numbers two consecutive prime numbers P1 < P2 whose
150 REM difference is greater than or equal to B (P2-P1 > = b).
160 REM
170 REM Test values - Results - VBas - CBas - VForth - CForth
180 REM A 1000,20 - 907, 887,20 - 48s 48s 18s 18s
190 REM B 2000,30 - 1361, 1327,34 - 118s 118s 30s 30s
200 REM C 9999,35 - 9587, 9551,36 - 1412s 1412s 374s 374s
210 REM D 32000,50 - 19661, 19609,52 - 3516s 3516s 1530s 1530s
220 REM E 32000,70 - 31469, 31397,72 - 10447s 10477s 2352s 2352s
230 REM F 500000,100 - 370373,3790261,112 - 45819s
240 REM
250 ZS = 3 : INPUT A,B
260 TIME$ = "000000":rem reset clock
270 FOR C = 3 TO A STEP 2
280 FOR D = 3 TO SQR(C) STEP 2
290 IF INT(C/D)*D = C THEN goto 330
300 NEXT D
310 IF C-ZS >= B THEN PRINT C,ZS,C-ZS : GOTO 350
320 ZS = C
330 NEXT C
340 PRINT " no solution " : GOTO 250
350 print "time", time$: goto 250
variable ZS 3 ZS !
variable A
variable B
variable match 0 match !
code jiffy
dex, sei,
$a1 lda, msb sta,x
$a2 lda, lsb sta,x
dex,
$00 lda,# msb sta,x
$a0 lda, cli, lsb sta,x ;code
( isqrt(n):
x = n \ x == old guess
y = (x + 1) / 2 \ y == new guess
while y < x:
x = y
y = (x + n / x) / 2
( Integer square root based on above )
( Returns the largest integer x )
( for which x * x does not exceed n )
: sqrt ( n -- root )
dup 1 + 1 rshift
begin
2dup /include
over + 1 rshift
swap over >
while repeat
nip
: dloop ( cloopI -- )
-1 nomatch !
dup \ cloop value
sqrt 4 max 3 do
dup dup I / I *
= if 0 nomatch ! leave then
2 +loop
drop
( pops all three bytes of jiffy clock
onto the stack as two unsigned doubles )
( -- ud ud)
code jiffy
dex, sei,
$a1 lda, msb sta,x
$a2 lda, lsb sta,x
dex,
$00 lda,# msb sta,x
( A B -- )
: benchmark
decimal
B ! A ! \ save A&B off stack
jiffy
A @ 3 do
I dloop nomatch @ if \ no match
I ZS @ - B @ -
0< invert if
I . ZS @ . I ZS @ - . leave then
I ZS !
then 2 +loop
jiffy
SYM (6502,1MHz) Basic1.1 BasBenc1 46,7 75,1 812,7 2014,0 3696,1 ____,_
C64 (6502, 1MHz) Basic BasBenc1 48,0 118,0 1412,0 3516,0 10447,0 45819,0 THX 2 Jeff_BirtCode: Select all
C64/SYM 1,02 1,57 1,74 1,75 2,83Code: Select all
Atari 800XL (1.79MHz NTSC) FastBasic_3.5 5.3 9.0 123.3 326.1 620.38
