AIM65 and the EPROM-burner described in INTERACTIVE07
oz6ym
Post by oz6ym »
I would like to make a EPROM-burner and found the diagram in INTERACTIVE07, but but..
The software for it is made in FORTH, and I do no FORTH, so I was thinking, if any one of you ever made this EPROM-burner, and have done the program for it?
If so, I will be very happy to receive a DUMP af this program, ready to burn into a EEPROM for my vingate AIM65 system.
In advance, Thanks for your help!
Vy 73 de OZ6YM, Palle
GaBuZoMeu
Re: AIM65 and the EPROM-burner described in INTERACTIVE07
Post by GaBuZoMeu »
Hi Palle,
could you either attach a link to the source you mentioned or the schematics?
Arne
See pages 10, 11, and 12 of issue 7:
http://6502.org/documents/publications/interactive/
GaBuZoMeu
Post by GaBuZoMeu »
Thank you, BigEd!
Palle, I have built something very similar for my SYM. The biggest difference in the hardware is, I didn't use a relay. I first set up the select switch (2716 <=> 2732) then insert the EPROM, and then turn on the SYM. The programing voltage is applied "by hand". My program issues a message when it is required.
You may take a look a it, and then perhaps know what to do on your AIM.
Arne
EDIT(1): one file is slightly corrupted, don't know how to remove it :oops: the upper one should be fine
EDIT(2): wrong one deleted :)
EPROMMER.ASM
(10.13 KiB) Downloaded 135 times
oz6ym
Post by oz6ym »
Hej Arne..
Thanks for the ASS-file.
Do you have any picture or diagram of your EPROM-programmer ?
Homepage maybee ??
de OZ6YM Palle
BillO
Post by BillO »
Edit your post, then scroll down to the section titled "Posted attachments". Find the unwanted attachment and click on "Delete file".
GaBuZoMeu
Post by GaBuZoMeu »
@BillO: THX :arrow: :idea:
@Palle:
I attached a quickly redrawn schematic. I have no picture - I couldn't find that board, perhaps it's gone, dunno.
At the top of the ASM file there is a sort of schematic. If there are discrepancies between the new one and the one within the ASM file, trust the old one!
Arne
EPROMMER.pdf
(38.17 KiB) Downloaded 149 times
oz6ym
Post by oz6ym »
Hello Arne!
Thank you very much for the drawing.
Here I can see that the difference to mine is quite small, only the relay change you do not have.
My final result can be seen here:
http://planker.dk/AIM65/eprom.htm
Thanks to you and BigEd for input.
de OZ6YM, Palle
GaBuZoMeu
Post by GaBuZoMeu »
Hej Palle,
it is looking fine. And a fine picture to show how easy wire wrap goes :)
Just never forget: some 2532 (and a few 2716 as well) don't like 25V !!
Happy burning :P
Arne
