> I'm not designing a heart-lung machine. If I were I'd be more prudent. In this case I'm designing a toy.
A very important point! We do see some very solid advice here on the forum which is appropriate for industrial-grade engineering, but that degree of rigour isn't always justified. It's still worth being careful which corners you cut, because an unreliable system isn't much fun to use or very easy to debug.
Another semi-fail - again with the W65C02
- BigDumbDinosaur
Re: Another semi-fail - again with the W65C02
BillO wrote:
I should point out here too that the 27CXXX series EPROMs we all use with abandon are also only rated at a Voh of 2.4V - and at a much lower 400uA.
But it won't be necessary unless the GAL is pretty darn slow.
As it turns out I have decided to do away with the delay for this project. It works without it and at a speed much higher than I am going to rate the project. I need the extra output pin on the GAL for something more practical.
Voh of the AMD 27C256-55 EPROM I'm using is Vcc × 0.7 minimum, which is definitely in CMOS logic 1 territory.
Yet in my other project the 15ns GAL limits the speed to below 15MHz. On that one I can get 17MHz with using a 7ns GAL.
For future reference, we have (by coincidence) had two threads going on at the same time both relating to glue logic and SRAM accesses:
- Another semi-fail - again with the W65C02 (BillO thread)
Slower SRAM works but fast doesn't???? (dolomiah thread)
- Project: semi-fail - suggestions please (BillO thread)
Perhaps it would be helpful to setup a sort of warning either as a pinned topic within the forum or perhaps within Garth's excellent primer. A warning to realize that the WDC 65C02 is not a plug in replacement for any 65(C)02. It only may work but the change in choosing a different timing origin (PHI2 instead of PHI2Out) is more important than (not only) a beginner may realize and can cause these strange "somehow it works but not fully" behavior.
Also mentioned in Garth's primer, but perhaps not prominent enough, the use of (too) fast components that may cause various trouble due to their speed when combined with slow signals and their impulsive current demands ("decoupling"). In the analog world of operational amplifiers and the like there the phrase "bandwidth of interest" is used. It should remind the designer to use appropriate components. Using much too fast components will nearly always end up in a redesign. This can be well compared to this (digital) world - using 10 ns RAMs in a 4 MHz design is not necessary and may cause trouble, slow 120ns types would be sufficient.
Arne
Arne
