It is currently Sat Nov 23, 2024 9:28 am
 Post subject: Bug or Feature?
PostPosted: Sat Mar 10, 2018 1:28 am
I have noticed that line beginning with a ':' are ignored by EhBASIC. Was this intentional or just a fortunate bug?
It allows a way to comment code sections in program files without incurring the overhead of REM statements.
For instance, when the following is sent to EhBASIC:
: The convention for variables and constants in this code is as follows:
:      A, AA and aA = variables/constants in main body
:      Aa =  global variables/constants
:      aa = variables/constants in subroutines
: It makes it easier for quick changes if global constants are defined one per line.
: Initialize global constants and variables here
10 Ix = 10
: constant - initial x index
20 Iy = 39
: constant - initial y index
30 Mx = 189
: constant - maximum x value for screen locations
. (etc...)
All those lines beginning with a colon are ignored.
 Post subject: Re: Bug or Feature?
PostPosted: Sat Mar 10, 2018 10:08 am
Good observation. It is a usefull but unintentional and undocumented feature. It only works that way in direct mode and allows comments in the source text while these comments will not be loaded to program memory. So a LIST in EhBASIC will not show them.
I wouldn't call it a bug as you are expected to enter a valid statement or line number in direct mode. The colon can be used as usual to separate further statements on the same line.
PostPosted: Sun Mar 11, 2018 6:00 pm
As you say, still useful.
Especially for me as I always keep my source open in Notepad++ and do all my changes there rather than directly on the target. The only thing I might od on the target is change the initial value of a variable or the value of a constant. Since I always define these one to a line to make that very job easier. Once the program is fully developed and sufficiently debugged you can always pack them many per line to save a bit of space if required. However, the biggest space saving comes from being able to comment the source without taking up space on the target.
Perhaps you could update your awesome version of the documentation with a note that outlines the 'feature'.
PostPosted: Tue Mar 13, 2018 9:00 am
I use a similar but more obvious technique to achieve the same thing. All REM lines in my programs have no line number. On load they will be executed as direct statements (do nothing) and will not be loaded to program memory.
