It is currently Sat Oct 05, 2024 8:35 am
 Post subject: C02 - Select statement
PostPosted: Tue Feb 06, 2018 4:21 am
See thread http://forum.6502.org/viewtopic.php?f=2&t=5066 for background.
When I originally tried to implement the switch statement in C02, I found that allowing fall through between case blocks generated code that was no more efficient than multiple if/then/else blocks.
Last night I realized that if each case block automatically terminated the switch, then each case statement could be a simple CMP and BNE.
My biggest concern was that deviating from the standard behavior of switch would cause confusion, and easily lead to mistakes in code.
I finally decided to use the keyword select instead. The syntax is identical to C's switch statement, however there is an implied break of the switch at the end of each case.
The updated code has been merged into branch master at https://github.com/RevCurtisP/C02
PostPosted: Tue Feb 06, 2018 4:25 am
Right now, a break statement inside a case or default block will exit the surrounding do, while, or for loop.
I'm thinking I should probably change this to exit out of the select block. instead, to allow premature termination of the case or default block.
PostPosted: Tue Feb 06, 2018 4:37 am
Here is a sample select statement
select (c) {
    case 0: //case block
    case 1: //case block
    case 3: //case block
    case 6: //case block
    case 10: //case block
    case 'A': //case block
    default: //default block
and the generated code
        LDA C          ;SELECT (C
        CMP #$00         ;) { CASE 0
        BNE L_0005       ;:
        //case block
        JMP L_0004       ;CASE
L_0005: CMP #$01         ;1
        BNE L_0007       ;:
        //case block
        JMP L_0004       ;CASE
L_0007: CMP #$03         ;3
        BNE L_0009       ;:
        //case block
        JMP L_0004       ;CASE
L_0009: CMP #$06         ;6
        BNE L_0011       ;:
        //case block
        JMP L_0004       ;CASE
L_0011: CMP #$0A         ;10
        BNE L_0013       ;:
        //case block
        JSR PUTLN        ;);
        JMP L_0004       ;CASE
L_0013: CMP #$41         ;'A'
        BNE L_0015       ;:
        //case block
        JMP L_0004       ;DEFAULT:
L_0015: //default block
L_0004:                  ;}
PostPosted: Tue Feb 06, 2018 4:45 am
It would be trivial to allow multiple arguments to a case statement, so that the C construct
switch (c) {
    case 1:
    case 2:
        //cases 1 or 2
       break;
    case 3:
        //case 3
       break;
    default:
        //everything else
would look like this in C02
select (c) {
    case 1,2:
        //cases 1 or 2
    case 3:
        //case 3
    default:
        //everything else
Does that seam reasonable?
PostPosted: Tue Feb 06, 2018 5:30 am
Just a few observations. I think if you are making something not C compatible, you should use whatever syntax you like. If you wanted to optimize a little, you could check if any of the cases are zero and put that case first so you can skip the CMP #00, since LDA sets the zero flag. If case 1 and 2 do the same thing, you might be able to do one CMP #03 followed by one BMI for case 1 and 2 followed by a BEQ for case 3. A few checks like that might make the code you generate a little smaller and faster.
Keep up the good work!
PostPosted: Tue Feb 06, 2018 7:44 am
I think a syntax for handling multiple matches is a good idea, and makes it a bit closer to C.
PostPosted: Tue Feb 06, 2018 11:24 am
I don't think its that big an issue, but using a different keyword is probably still wise so people don't just C&P a block of normal C code and not be aware of the differing semantics
Having said that, structures like this are actually quite common - the entire Visual Basic line (all the way up to VB.Net 2017 or whatever the latest version is) has a Select Case statement that uses exactly these semantics, including implied break on next case. A lot of more modern languages like Go and Rust also eschew fall-through; the argument being that "forgetting a break" is very common and causes many bugs, but the flexibility of allowing fall-through is useful only occassionally.
VB.Net e.g.
    Public Function WhatNumber(ByRef Number As Integer)
        Select Case Number
            Case 1
                MsgBox("1")
            Case 2, 3
                MsgBox("> 1, < 4
            Case Else
                MsgBox("> 3")
        End Select
    End Function
PostPosted: Tue Feb 06, 2018 8:27 pm
The select case was also in QBASIC/QuickBASIC. I don't think it was in GW-BASIC/BASICA, though.
PostPosted: Wed Feb 07, 2018 12:55 am
If you can have "goto"s inside the select block, that would let the user manually enable fall through and tail sharing only in cases where they explicitly need it.
PostPosted: Wed Feb 07, 2018 1:45 am
There's nothing preventing that. It's possible to goto in and out of any type of control structure.
EDIT: I just wrote a test case veriifying that this works.
for (c=5; c<=9; c++) {
  prbyte(c);
  putc(' ');
  select (c) {
    case 9:
      puts("WORKING NINE TO ");
      goto five;
    case 5:
      five: putln("FIVE");
    default: putln("*");
which resulted in
05 FIVE
06 *
07 *
08 *
09 WORKING NINE TO FIVE
PostPosted: Wed Feb 07, 2018 2:46 am
I modified the code so that if the first argument of the first case is 0, the initial CMP is skipped.
Instead of this, I'm thinking a special argument type, <TERM which would generate a BCS to jump over the case block. Maybe a >TERM as well, but that would be a little more complicated.
Thanks.
PostPosted: Wed Feb 07, 2018 2:49 am
I added multiple arguments to a case, separated by commas.
PostPosted: Wed Feb 07, 2018 4:29 am
I found and fixed a bug with if's inside a case statement and updated branch "master", then I created branch "break-case" and modified the code so that a break statement will exit out of the select instead of the surrounding loop.
I think I'm done for the night.
PostPosted: Thu Feb 08, 2018 9:53 pm
I merged the break-case branch into master on GitHUb last night, so a break statement inside a case will now exit theselect.
Users browsing this forum: Google [Bot] and 5 guests
