It is currently Wed May 22, 2024 3:31 pm
PostPosted: Tue Jan 17, 2017 1:00 am
Within another thread, there was a suggestion for changing certain function returns from signed to unsigned. One other fix I thought of that is probably very easy is upper-case/lower-case key word interpretation...unless there is some compilation switch I missed somewhere. I keep forgetting to put on the CAPS LOCK so I keep getting errors. Minorly annoying, but I thought I'd mention it if people are thinking of making changes to the code.
Rich Cini
Build Master and maintainer of the Altair32 Emulation project
http://cini.classiccmp.org
http://altair32.classiccmp.org
PostPosted: Tue Jan 17, 2017 10:45 am
(Just for reference, that was perhaps this discussion
viewtopic.php?p=48612#p48612
which, I think, is about FRE(0) returning a signed number)
PostPosted: Tue Jan 17, 2017 9:04 pm
Yup, correct. That's it. Thanks BigEd.
Rich Cini
PostPosted: Wed Jan 18, 2017 11:04 am
That's what I did in my port to my homebrew machine, check out this commit:
https://bitbucket.org/steckschwein/stec ... 6b0a20653f
the toupper macro just contains
cmp #$60 ; Is lowercase?
   bcc :+
   and   #$DF
This modification only makes the tokenizer case insensitive, LIST will still show keywords in uppercase and you will get uppercase and lowercase variable names as a bonus.
PostPosted: Wed Jan 18, 2017 12:46 pm
   bcc :+
   and   #$DF
Ahhh, this is really good. I'll give it a try. Thanks!
Rich Cini
PostPosted: Thu Jan 19, 2017 8:01 am
Let me know if you run into any issues. I am quite new to EhBasic, it's very likely I overlooked something.
PostPosted: Thu Jan 19, 2017 2:57 pm
I like the patch. There is just a tiny problem. Characters in variable names not in the token dictionary get converted to upper case.
new
Ready
10 aj=kl+pqr
list
10 aJ=Kl+pQr
Ready
Characters not in the dictionary are JKQXYZ. To restore the lower case character after an unsuccessful dictionary search you must redirect a branch
LAB_13D0
      CMP   (ut2_pl),Y        ; compare with keyword first character table byte
      BEQ   LAB_13D1          ; go do word_table_chr if match
; *** replace
;      BCC   LAB_13EA          ; if < keyword first character table byte go restore
; *** with
      BCC   PATCH_LC2         ; if < keyword first character table byte go restore
; *** end
                              ; Y and save to crunched
to a new label
                              ; now find the end of this word in the table
LAB_141B
      LDA   (ut2_pl),Y        ; get table byte
      PHP                     ; save status
      INY                     ; increment table index
      PLP                     ; restore byte status
      BPL   LAB_141B          ; if not end of keyword go do next
      LDA   (ut2_pl),Y        ; get byte from keyword table
      BNE   LAB_13D8          ; go test next word if not zero byte (end of table)
                              ; reached end of table with no match
; *** add label
PATCH_LC2
; *** end
      LDA   Ibuffs,X          ; restore byte from input buffer
      BPL   LAB_13EA          ; branch always (all bytes in buffer are $00-$7F)
                              ; go save byte in output and continue crunching
If there is no objection i will add the complete patch to my list. https://github.com/Klaus2m5/6502_EhBASI ... ds_mod.txt
edit: updated where to find the patch
PostPosted: Thu Jan 19, 2017 6:04 pm
Ha, I knew I'd overlook something. I applied you patch and it works perfectly.
Klaus2m5 wrote:
If there is no objection i will add the complete patch to my list. https://github.com/Klaus2m5/6502_EhBASI ... quirks.txt
No objection from me.
PostPosted: Thu Jan 19, 2017 6:58 pm
I'm good with it. Thanks!
Rich Cini
PostPosted: Wed Jan 17, 2018 5:40 pm
Hey guys,
Sorry for waking a relatively old thread, but I was working with the 6502 badge and had challenges with the upper case requirements. Before finding this thread I had already written prototype code to fix this and it's a bit different from what I found here so I thought I'd share for review.
The code is written to patch the badge version of EhBASIC so labels may differ some, and the patch quoted at the bottom will almost certainly not cleanly apply.
First, a bit of my mind: The difference between upper case and lower case is $20, calculated by subtracting 'A' from 'a', $61 - $41. This inverted becomes $DF, a mask to either convert lower to upper case with AND, or to similarly mask a mismatch while using EOR as a compare:
+; jbev start
+       EOR     Ibuffs,x                ; check bits against table
+       AND     #$DF                    ; DF masks the upper/lower case bit
+; was: CMP     Ibuffs,X                ; compare with byte from input buffer
+; jbev end
As seen above, the CMP was replaced with EOR:AND. This does slow the tokenize code down, but as it's generally only used during program entry I feel it's worth the performance loss.
Any thoughts on this method? As a very novice assembly programmer I may have some error in my logic but by this point there shouldn't be anything but alpha characters in .A and during the full-keyword search. The only flaw is when handling the first-character search, so a bit more patching would be needed to prevent J from matching *, for example. The code is also modified with space in mind. I could unroll the loops for speed during the first eight checks but didn't consider it worth the extra bytes in memory to save some 24 cycles.
The text below is a 'diff' format patch between the original and modified code.
--- basic.asm.orig      2018-01-17 11:30:35.152970124 -0500
+++ basic.asm   2018-01-17 12:29:05.407284754 -0500
@@ -1053,8 +1053,25 @@
        LDY     #$00                    ; clear table pointer
 LAB_13D0
+; JBEV - refactor this for case insensitive tokenization
+; Yes, this slows down tokenization, but it's not a routine that gets
+;   used often, so a bit of slowdown here should be ok.
+; The first step, EOR, will result in a zero output on uppercase match,
+;   and a $20 on lowercase match.
+; The second step, AND #$DF, will mask that $20 bit so the original BEQ
+;   will function as normal for the token match search.
+; jbev start
+       CPY     #8                      ; do a standard compare for the non-alpha entries.
+       BCS     JB_LC1                  ; not at the 'A' ent yet?
-       BEQ     LAB_13D1                ; go do word_table_chr if match
+       JMP     JB_LC2                  ; jump around the patch
+JB_LC1 EOR     (ut2_pl),Y              ; check bits against first char table byte
+; jbev end
+JB_LC2 BEQ     LAB_13D1                ; go do word_table_chr if match
@@ -1063,6 +1080,8 @@
        BNE     LAB_13D0                ; and loop (branch always)
 ; have matched first character of some keyword
+; JBEV - refactor this for case-insensitive tokenization
+; JBEV - the EOR/AND route was taken as the high bit test is necessary at 13D6.
 LAB_13D1
        TYA                             ; copy matching index
@@ -1084,7 +1103,13 @@
        BMI     LAB_13EA                ; all bytes matched so go save token
        INX                             ; next buffer byte
-       CMP     Ibuffs,X                ; compare with byte from input buffer
+; jbev start
+; jbev end
        BEQ     LAB_13D6                ; go compare next if match
        BNE     LAB_1417                ; branch if >< (not found keyword)
PostPosted: Thu Jan 18, 2018 10:15 am
You forgot to restore A after it is destroyed by EOR/AND! Did you ever test your patch?
PostPosted: Thu Jan 18, 2018 2:19 pm
Thanks! I haven't tested yet, and knew I was missing something but wasn't sure what :)
PostPosted: Sat Jan 20, 2018 1:12 pm
After I took a closer look it appears that the second part of jbevren's patch is faster and shorter than mine. So I will change the patch accordingly.
PostPosted: Thu Jan 25, 2018 2:40 pm
Please do. I haven't had opportunity to test the patch yet however, keep this in mind. :)
