Cannot show schematic now, when i go back in my office can show.
Anyway i think is just a software problem, because, as told, ISR work fine without FIFO enabled.
I no have experience with this kind of chip and i tried to follow suggestions found in an old "Application Notes AN-0491" by National Semiconductor ("The NS16550A: UART Design and Application Considerations").
Both datasheet from T.I. and EXAR say that TX FIFO can be loaded with 16 bytes while servicing TX interrupt, and that the reciver buffer can be readden until "data ready bit" (LSR<0>) is set.
Below show the extracted part of the involved software, with ISR routine and routines for get/put a byte from/into buffer.
; some useful macros
PNFLAG .EQU 10000000B ; Negative flag
PVFLAG .EQU 01000000B ; Overflow flag
PMFLAG .EQU 00100000B ; Acc/Mem 8 bit flag
PXFLAG .EQU 00010000B ; Index 8 bit flag
PDFLAG .EQU 00001000B ; Decimal flag
PIFLAG .EQU 00000100B ; IRQ disable flag
PZFLAG .EQU 00000010B ; Zero flag
PCFLAG .EQU 00000001B ; Carry flag
INDEX16: .MACRO
.MLIST
rep #PXFLAG
.LONGI on
.MNLIST
.ENDM
INDEX08: .MACRO
.MLIST
sep #PXFLAG
.LONGI off
.MNLIST
.ENDM
CPU08: .MACRO
.MLIST
sep #(PMFLAG.OR.PXFLAG)
.LONGA off
.LONGI off
.MNLIST
.ENDM
ACC08: .MACRO
.MLIST
sep #PMFLAG
.LONGA off
.MNLIST
.ENDM
ACC16: .MACRO
.MLIST
rep #PMFLAG
.LONGA on
.MNLIST
.ENDM
SPOUTBUFF4 .EQU $05E000 ; TX buffer
SPINBUFF4 .EQU $05F000 ; RX buffer
SOBUFSIZ4 .EQU $1000 ; TX buffer size
SIBUFSIZ4 .EQU $1000 ; RX buffer size
NGUARD4 .EQU $0100 ; count of guard bytes for deassert CTS
NFREE4 .EQU $0400 ; min. count of free bytes in RX buffer for assert CTS
UARTDP .EQU $0500 ; direct page
; uart 16C550 at $00FF20
UART_RXTX .EQU $00FC20 ; DLAB=0
UART_IER .EQU $00FC21 ; DLAB=0
UART_DLL .EQU $00FC20 ; divisor latch low, DLAB=1
UART_DLH .EQU $00FC21 ; divisor latch high, DLAB=1
UART_IIR .EQU $00FC22 ; Int. Ident. Reg., read only
UART_FCR .EQU $00FC22 ; FIFO Ctrl Reg., write only
UART_LCR .EQU $00FC23 ; Line Ctrl Reg.
UART_MCR .EQU $00FC24 ; Modem Ctrl Reg.
UART_LSR .EQU $00FC25 ; Line Status Reg. (read only)
UART_MSR .EQU $00FC26 ; Modem Status Reg. (read only)
UART_SCP .EQU $00FC27 ; scratchpad reg.
; DIRECT PAGE variables's to handle 16C550
spmode4 .DB ; <7>: 0=no handshake, 1=handshake
; <6>: 0=software/1=hardware handshake
; <5>: if = 1 FIFO is disabled
; <4>: not used
; <3>: 0=odd parity, 1=even parity
; <2>: 0=no parity, 1=parity as specified
; by bit <3>
; <1:0> : baud rate
; 00 = 19200
; 01 = 38400
; 10 = 57600
; 11 = 115200
splin4 .DB ; <7>: /DSR line level
; <6>: /CTS line level
sppause4 .DB ; local/remote pause flag's
; <7>: remote pause (sent an XOFF or set RTS=1)
; <6>: local pause (received an XOFF or CTS=1)
spcnt4 .DB ; count of bytes to send while tx interrupt
spstat4 .DB ; status
; <7>: rx error (data discarded)
; <6>: rx buffer overrun
; <5>: remote disconnession (/DSR line = 1)
; <4>: output buffer overrun
; <3>: received a break
; <2>: framing error
; <1>: parity error
; <0>: overrun error
sptmp4 .DB ; used for save X reg. while get/put routine and by ISR
uartlsr .DB ; save UART LSR reg. while ISR
uartiir .DB ; save UART IIR reg. while ISR
ibuftail4 .DW ; pointer to tail of input buffer (get routine use it)
ibufhead4 .DW ; pointer to head of input buffer (ISR routine use it)
obuftail4 .DW ; pointer to tail of output buffer (ISR routine use it)
obufhead4 .DW ; pointer to head of output buffer (put routine use it)
ibufcnt4 .DW ; current count of bytes stored in input buffer
obufcnt4 .DW ; current count of bytes stored in output buffer
icntmin4 .DW ; min. count of bytes in rx buffer for clear remote pause
icntmax4 .DW ; max. count of bytes in rx buffer for set remote pause
; CODE SECTION
; init serial port 16C550
; A=mode (like in spmode4)
; At this time just harware handshake is implemented
; WARNING: assume DBR = 0
spset4:
sei ; disable interrupt
phd
pea #UARTDP
pld
sta spmode4 ; save mode
stz !UART_LCR
stz !UART_IER ; disable all UART interrupts
stz !UART_MCR ; /RTS and /DTR high
stz !UART_FCR ; disable FIFO
ldx .ABS.UART_RXTX ; clear any pending interrupt
ldx .ABS.UART_LSR
ldx .ABS.UART_IIR
ldx #$80 ; set DLAB = 1 in LCR
stx .ABS.UART_LCR
tay ; save mode
and #00000011B ; baud rate select
tax
lda >?div,x ; select divisor
sta !UART_DLL ; set low latch
stz !UART_DLH ; set high latch
tya ; mode
and #00001100B ; mask on bits 3 & 2 (parity mode)
asl a ; shift <3:2> to <4:3>
ora #00000011B ; 8N1 (8 bits data, 1 stop bit)
sta !UART_LCR
lda !UART_MSR ; get /DSR & /CTS status
tax
asl a
asl a ; <7>: /DSR, <6>: /CTS
and #11000000B
eor #11000000B
sta splin4 ; update line status
stz sppause4 ; init work area
stz spstat4
lda #1 ; set tx count = 1
sta spcnt4
CPU16 ; init buffer's pointer's
lda #NGUARD4
ldy #NFREE4
sta icntmax4
sty icntmin4
sec
lda #SIBUFSIZ4
sbc icntmax4
sta icntmax4
stz ibuftail4
stz ibufhead4
stz ibufcnt4
stz obuftail4
stz obufhead4
stz obufcnt4
CPU08
lda #00000011B ; set /RTS = /DTR low
sta !UART_MCR
lda #$20
bit spmode4
bne ?nof ; no fifo
lda #10000111B ; enable fifo, reset rx/tx fifo, trigger level = 8
sta !UART_FCR ; rx fifo trigger = 8
lda #16 ; set tx count = 16 in FIFO mode
sta spcnt4
?nof: lda !UART_LSR ; again reset all interrupts
lda !UART_MSR
lda !UART_IIR
lda #00001111B ; enable all interrupts
sta !UART_IER
pld
cli
rts
; 19.200, 38.400, 57.600, 115.200
?div: .DB 6, 3, 2, 1
; ISR routine (prologue and epilogue code for context switching not showed here)
; handle 16C550 interrupt
; WARNING: assume DBR = 0 and DP saved by interrupt handler prologue code
uartisr:
pea #UARTDP
pld
lda !UART_IIR
sta uartiir ; save for late check FIFO enabled
lsr a ; if bit <0> = 1 no interrupt
bcc $+3 ; interrupt pending
rts
and #0000011B ; mask on priority code
asl a
tax
; RX timeout interrupt and RX data available interrupt use the same routine
jmp (?uarttbl,x) ; jump to right routine
?uarttbl:
.DW ?msr, ?tx, ?rx, ?lsr
?lsr: jsr uartlsr
rts
;bra uartisr ; check again interrupt (was a test)
?msr: jsr uartmsr ; MSR: modem status register
rts
;bra uartisr ; check again iterrupt
?tx: jsr uarttx ; TX FIFO or THR is empty
rts
?rx: jsr uartrx ; data available in RX FIFO or RHR
rts
; this interrupt is raised when one of the modem lines change state
; here just DSR and CTS are used: DSR for signaling remote disconnession,
; CTS for hardware handshake (put local TX in pause)
uartmsr:
lda !UART_MSR ; clear interrupt
tax
asl a
eor #$C0
bit spmode4
bpl ?end ; no handshake: ignore line changes
tay
bpl ?cts ; /DSR is low, check /CTS
lda #$A0 ; /DSR is high
tsb spstat4 ; remote terminal disconnected
?cts: txa
lsr a ; check /CTS transition
bcc ?end ; no /CTS transition
ldx #$40 ; local pause flag
tya
asl a
bpl ?clp ; transition /CTS high->low: clear local pause
txa
tsb sppause4 ; /CTS high -> set local pause
lda #00000010B ; disable TX interrupt
trb !UART_IER
rts
?clp: txa
trb sppause4 ; /CTS low -> clear local pause
lda #00000010B ; enable TX interrupt
tsb !UART_IER
?end: rts
; this interrupt is raised either when THR is empty
; or when TX FIFO is empty
uarttx:
trb !UART_IER
bit sppause4 ; local pause is set ?
bvs ?done ; yes, no tx possible at this time
INDEX16
ldy obufcnt4 ; count of bytes in output buffer
beq ?done ; nothing to send at this time
ldx obuftail4 ; pointer to tail of out buffer
lda spcnt4 ; set the bytes count
sta sptmp4
?txl: lda >SOBUFADDR4,x ; get data from the tail of output buffer
sta !UART_RXTX ; load data into FIFO/THR
inx ; update head pointer
ACC16
txa
and #(SOBUFSIZ4-1) ; circular queue
tax
ACC08
dey ; update count
beq ?upd ; nothing else to send
dec sptmp4
bne ?txl ; loop: load more bytes if FIFO enabled
?upd: stx obuftail4
sty obufcnt4
?done: CPU08 ; NOTE: tx interrupt will be re-enabled by put routine
rts ; or by a negative /CTS transition
; this interrupt is raised when receive a byte with some errors
uartlsr:
lda #00000101B ; disable LSR & RX interrupt
trb UART_IER
lda !UART_LSR ; get line status and clear interrupt
sta uartlsr ; save for further debugging
lsr a ; CF = 1 if available a new rx byte
and #$0F ; mask on rx errors
ora #$80 ; set rx error bit
sta spstat4 ; set status register
bcc ?done ; no new char received
lda !UART_RXTX ; get top fifo data or THR & discard
bit uartiir
bvc ?done ; no FIFO enabled
lda #10000011B ; clear RX FIFO
sta !UART_FCR
?done: rts ; after rx error, rx interrupt are disabled
; this interrupt is raised either when RHR is full or when RX FIFO reach the
; programmed trigger level (in this case 8)
uartrx:
lda #$01 ; disable RX interrupt
trb UART_IER
INDEX16
ldy ibufcnt4 ; count of bytes in input buffer
ldx ibufhead4 ; pointer to head of input buffer
?loop: lda !UART_LSR ; get line status
sta uartlsr
bcc ?done1 ; no data available, re-enable rx int. & exit
xba ; save error code
xba
?tst: beq ?rx ; no rx error pending
bra ?sst ; set status reg. & discard received data
?rx: xba ; A = received data
cpy icntmax4 ; check input buff. for remote pause condition
bcc ?str ; below guard limit: store data
xba ; B = received data
lda #00000010B ; hardware handshake...
trb !UART_MCR ; ...set RTS=1
lda #$80 ; set remote pause flag
tsb sppause4 ; bit 7=1 -> remote pause on
?chk: cpy #SIBUFSIZ4 ; left room in input buffer?
bcc ?str ; yes, store received byte
lda #$C0 ; set bit 7: rx error, bit 6: rx overrun
?sst: sta spstat4 ; set status register
bra ?done ; discard received data & exit
?str: sta >SIBUFADDR4,x ; now store received data
iny ; update bytes count
inx ; update rx head pointer
ACC16
txa
and #(SIBUFSIZ4-1) ; circular queue
tax
ACC08
bra ?loop ; check again if rx data available
?done: stx ibufhead4 ; save rx head pointer
sty ibufcnt4 ; save bytes count
?done1: INDEX08
lda #$01 ; re-enable rx interrupt
tsb UART_IER
rts
; get a byte from input buffer and return in A
; return:
; CF = 0, A = byte from queue
; CF = 1, A = 0 if no new byte available
; CF = 1, A > 0 if rx error (A = error code)
spget4:
phd
pea #UARTDP
pld
sec ; assume error
stx sptmp4 ; save X reg.
lda spstat4 ; rx pending error?
bmi ?done ; yes, exit (CF = 1, A = error code)
lda #0 ; assume no data available
tay ; Y = 0
INDEX16
ldx ibufcnt4 ; available new data?
beq ?done ; input queue is empty (exit with CF=1, A=0)
dex ; update count
stx ibufcnt4
ldx ibuftail4 ; tail input buffer pointer
lda >SIBUFADDR4,x ; get byte from queue
inx ; update tail pointer
cpx #SIBUFSIZ4
bcc ?upd
tyx ; circular queue
?upd: stx ibuftail4
bit spmode4 ; handshake is on?
bpl ?ok ; no, exit
bit sppause4 ; remote pause is on?
bpl ?ok ; no, exit
ldx ibufcnt4
cpx icntmin4 ; can clear remote pause?
bcs ?ok ; no, exit
xba ; save data
tsb !UART_MCR ; ...set /RTS=0
lda #$80
trb sppause4 ; clear remote pause flag
lda #00000010B ; set IER<1>
tsb !UART_IER ; re-enable tx interrupt
xba ; recover data
?ok: clc ; no error
?done: CPU08
ldx sptmp4 ; restore X reg.
pld
cli
rts ; CF=1 & A=0 mean: no data available
; put a byte in the output buffer
spput4:
phd
pea #UARTDP
pld
ldy #0 ; Y = 0
INDEX16
ldx obufcnt4
cpx #SOBUFSIZ4 ; output buffer is full?
bcc ?str ; no, store byte
bit splin4 ; test /DSR line status
bmi ?ofl ; remote terminal disconnected
xba ; save A
lda #00000010B ; enable TX interrupt...
tsb !UART_IER ; ... hoping that ISR can make room in output buffer
xba
bra ?done ; exit with CF=1, Y=0: output buffer is full
?ofl: dey ; /DSR high
xba
lda #00000010B
trb !UART_IER ; disable tx interrupt
xba
bra ?done ; exit with CF=1, Y=$FF: remote terminal offline
?str: inx ; update count
stx obufcnt4
ldx obufhead4 ; output buffer head pointer
sta >SOBUFADDR4,x ; store byte in output buffer
cpx #SOBUFSIZ4
bcc ?upd
?upd: stx obufhead4
xba
lda #00000010B
xba ; return A = sent data
clc ; no error
?done: INDEX08
pld
cli
rts
http://65xx.unet.bz/ - Hardware & Software 65XX family
