It is currently Sat Nov 23, 2024 7:03 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Fri Nov 10, 2017 6:45 pm
But a fat VCC trace can actually be a disadvantage in certain troubleshooting situations, such as when a chip or a bypass cap has shorted. You're better off to have skinny VCC traces because their resistance is high enough that there'll be a measurable voltage drop across the trace that feeds the shorted component. (Have been there and done this IRL -- a tidy solution to an otherwise nasty situation.)
I made myself a short-finder for this purpose, that puts 2A pulses through, at less than 2% duty cycle, and I can use the oscilloscope on the 5mV/div vertical gain setting to probe around the board and track down the short, even between planes (which usually means where there's a shorted capacitor that goes from one plane to another, but you can even detect where a short is in the board itself!). Here's the sheet in my 3x5" workbench quick-reference guide:
The op amp is just a cheap LM358 8-pin dual op amp.
PostPosted: Fri Nov 10, 2017 6:51 pm
Pulsing the current- I like that. Would an infrared camera help at all?
PostPosted: Fri Nov 10, 2017 8:09 pm
An IR camera might help if you don't pulse the current but limit limit the current to the highest level the traces can safely handle. A 2A pulse for less than 2% duty cycle is less than 40mA average which will only raise a .008" trace's temperature by about 1.5°C (and take a long time to do it). If the traces are underneath components though, or on an inner layer, it will be extra difficult. For a short between planes (which hopefully will be at a component), depending on the component, the current may have to be awfully high to find the short with an IR camera.
PostPosted: Fri Nov 10, 2017 10:12 pm
I should note that when building the first copy of a new design, I meter out the bare board before populating it to catch the shorts that accidentally got designed in the layout. :shock: If the metering out process seems to be okay, I attach the power connector, apply power and assuming the power supply doesn't fault out ("crowbar" in railroad electric traction parlance—not the technically correct usage), I check all points that are supposed to be powered for the presence of power.
With the above checks handled, I populate the board, periodically checking for a low resistance or short between Vcc and ground, especially after installing an electrolytic (POC V1.0 had a reversed electrolytic error that I caught during assembly-stage testing). By the time the board is fully populated I'm reasonably confident that I'm not going to power up into a catastrophic fault. That, of course, doesn't mean that a defective part couldn't go bang, but in practice, that has very seldom happened. In fact, it's literally been years since I last got a new IC that was defective.
The above process may sound like something a Nervous Nellie would do, but in practice it has saved the day more than once. Burned-up carbon comp resistors don't smell very good and I especially loathe having to clean up after an improperly-installed electrolytic blows following power application—had that happen in a 100 watt vacuum tube PA amp and, boy, did it make a mess of things. :oops:
Something that could be done when first-time powering a gadget is to insert a low wattage incandescent lamp in series with Vcc to act as a fault current limiter. I'm "braver" than that and depend on the power supply to automatically shut down if a fault occurs. That may not save parts but it will in most cases prevent PCB damage so a post mortem can be conducted.
Users browsing this forum: No registered users and 37 guests
