Very nice, Axel! If you're able to run Basic then things are going well,obviously! For a final shakedown do you eventually plan to run Klaus's test suite?
A couple of things caught my attention in the schematic. You seem to have a sixteen-bit Stack Pointer, so what up with that??
Also I was wondering if the chip families are as shown -- HC and LS families, for example.
Will you also publish the number of cycles for the various instructions? I'm curious how the cycle counts compare with those of an actual 6502. Also I don't quite understand your comment in your previous post about a slow shift right implementation.
On page one of this thread you posted a
block diagram. I assume this has remained unchanged. But if you ever redrawn the diagram it would be nice to see a little more detail, in the control section especially. Congratulations on a great project!
cheers
