It is currently Fri Nov 22, 2024 11:01 pm
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Mon Aug 14, 2017 7:21 am
Ax2013 wrote:
Using ROMs in SR logic does not limit max speed more - those same ROMs are being used in control logic already so the limitation exists already.
To me, the critical delay path now looks like this:
Phase counter > Microcode ROMs > register read decoder + register read > ALU > flag evaluation logic + ROM > SR.
For functional testing, feeding the CPU external data bus with a DIP switch (plus pullup resistors) would be nice for a start.
If a permanent $A9 on the data bus loads the accumulator with $A9 while incrementing the PC,
quite some part of the CPU seems to work as intended...
BTW: peeling most of the bugs out of the M02 microcode took about 3 months. :)
PostPosted: Mon Aug 14, 2017 8:22 am
Yes of course. That's what I have been doing so far. Everything works with manual control. Including phase control, IR load, PC++, register loads, mem read/write, (ALU) SHL, etc.
Breadboard wiring and testing so far: 35h
It was nice that my timing/clock design worked on first try. Phase control/IR load/PC++ in Phase0 before actual operations was one of my design goals. Whether everything continues to work with the actual control logic... that remains to be seen...
Axel.
PostPosted: Mon Aug 14, 2017 12:07 pm
There is no new delay due to Flag ROM, because between "ALU output"/"memory output"/"memory input" etc AND phase end there must be a long delay. RAM write has 85ns max delay while ROM read has 70ns. So if Flags ROM+logic is below 85ns it is not limiting my second time period.
If you take a look the timing diagram, thats the time period between "IR latch" and "Register latches".
Dropping delays of logic chips out of the equation the max frequency is 5.9MHz. One instruction phase is one clock cycle in this state machine.
I would consider 1MHz a victory and probably won't go much faster than that (well... we'll see about that... :-) )
Axel.
PostPosted: Fri Aug 18, 2017 6:02 pm
Microcode ROMs in and testing:
LDA #$62
ADC #$13
STA $0008
$0008=
Looks like I may call this a computer :-)
Axel.
PostPosted: Sat Aug 19, 2017 6:37 pm
Pull back! I'd love to see a photo of the whole thing powered on.
PostPosted: Sun Aug 20, 2017 5:09 pm
Here you go:
Top to bottom:
Databus value
PC
AR (control signal logic on right)
Membus multiplexer (Run/Prog mode)
RAM (and Prog mode address+value)
IR (control signal logic on right)
Phase counter + microcode ROMs
Full address + substraction (=XORs) and reset
A and T regs
Clock signal generation + manual clock/555 oscillator
Flag generator + Zero flag calculator + SR
PostPosted: Sun Aug 20, 2017 6:55 pm
Well done!
PostPosted: Sun Aug 20, 2017 9:09 pm
Well done!
Thanks. I'm starting to route the first version of pcb soon. It seems that everything on board works as planned.
Btw: what happens in real 6502 when reset is released in the middle of clock pulse? In my case it starts to execute cleared IR (opcode $00) which happens to be a valid instruction. That needs to be resolved somehow...
Axel.
PostPosted: Sun Aug 20, 2017 9:36 pm
It does not matter what part of the clock cycle you're in when you release RST\. It always does the same thing, regardless.
PostPosted: Sun Aug 20, 2017 11:50 pm
Ax2013 wrote:
Here you go:
A huge amount of work. Well done! Nice labels!
PostPosted: Wed Aug 23, 2017 4:37 pm
9.7x8"
douple side
few cups of coffee...
PostPosted: Wed Aug 23, 2017 7:05 pm
Ax2013 please verify the actual case dimensions of your ICs. The ones with 14 pin (U67/68) might actually be larger so that the space between them is nearly zero and then there is no room left for what I assume are decoupling Cs. If you will use sockets the space between them may be sufficient for small axial type Cs, but w/o sockets ... :shock:
PostPosted: Wed Aug 23, 2017 7:50 pm
Thanks for the heads-up. There is enough space - actually I've added 25mils extra between decoupling caps and ICs. The space between ICs is about twice of a ceramic cap width.
Axel.
PostPosted: Wed Aug 23, 2017 9:08 pm
Amazing progress! I really like the way the datapath is laid out. One question: how does your microcode handle writing PC to the stack since both PC and SP connect directly to the address bus?
PostPosted: Thu Aug 24, 2017 5:17 am
Thanks Drass!
PC address to stack can be written through T reg. (HI/LO Addressbus gateway to left ALUbus - see the logical diagram few posts earlier).
Axel.
Users browsing this forum: Google [Bot] and 25 guests
