Despite all that, TIA-232 is still in widespread use, and based upon what I see as I go around my daily business, will likely be around when my grandson has retired (he's got about 44 years to go). It's hard to say how long VGA will be around, but I suspect it will be in use when I'm pushing daisies. An instructor of mine opined long ago that new technology isn't necessarily better technology. My nearly 50 years of activity with computers and electronics affirms that opinion.
VGA has five years to live
- BigDumbDinosaur
Re: VGA has five years to live
commodorejohn wrote:
It's been 6-1/2 years since this was posted and VGA is still going strong.
- Oneironaut
You know what else is still around?.... PS2 keyboards!
Who woulda thunk it??
Apparently, gamers use these, so the PS2 port is present on almost all high end mainboards.
For this reason, they ere are still many sources, and companies are making these new.
For these reasons, I am using both VGA and PS2 and a brand new project I have been working on lately.
Long live Old-School!
- Alarm Siren
From what I understand, the reason PS/2 keyboards are popular with gamers is down to the protocol and controller architecture. Essentially, with PS/2 the keyboard can push messages to the PC and they get dealt with in an interrupt, whereas USB the keyboard has to be polled by the PC. Anyway, the net result is that PS/2 theoretically has lower latency. Whether this is noticably better I have no idea, but that's the theory.
OT: I too am fond of VGA. Had to build a VGA controller on an FPGA for uni, and it was surprisingly and elegantly simple.
- commodorejohn
Also I believe there's an issue with the USB keyboard standard where it boneheadedly only supports three keys being pressed simultaneously, which can cause all kinds of devilish mischief in action games with middling-to-large numbers of key-mapped controls. Or at least that was the case back in the WinMe era when I last used a USB keyboard on a PC, no idea if it still is now.
Or someone who appreciates proper color contrast and upscaling that isn't an ugly, blurry mess
Fortunately, things have greatly improved, although I still prefer the picture of a CRT monitor over that of an LCD panel. I guess I'm just an out-of-touch curmudgeon.
- BigDumbDinosaur
- Alarm Siren
Dunno how the behavior is different, if at all.
- BigDumbDinosaur
Alarm Siren wrote:
And the weight. You try hooking a 50" plasma telly off the third shelf in a warehouse, with the customer waiting. And then trying to squeeze it into his old-style Mini.
As for VGA; the new LG 55" LCD I bought last year still had VGA and analog input. I even managed to get it to lock onto the output of a Vic-20(!). Its so thin you can almost use it as a blanket - no wonder some people are stealing them so easily.
PS/2 equipment is also used in high-data security environments. When my previous employer sent people to Goldman Sachs in the early 2000s they found that GS policy called for disabling the USB ports on every company system.
I'm still bummed that parallel ports have almost entirely vanished.
- Alarm Siren
Well, I suppose that makes sense. At a protocol level you can't use PS/2 devices to take information off a computer, whereas a USB keyboard could also emulate a flash drive and copy stuff off when you're not looking. You could still cause some havoc with a PS/2 keyboard that types by itself though.
I was surprised to see that it had a parallel printer port on it alongside a T-10/100 Ethernet port. So I guess they haven't died 100%.
IIRC they had noticed by accident, that a certain optical USB mouse (manufactured in China)
had that habit when getting moved over a mouse pad (manufactured in China) which had microscopic "dots" on it,
the mouse "enumerated" itself as a keyboard too, opened a "console window" running in the background on the PC,
then "typed in" the commands for downloading malware from the internet from a location specified by that dot pattern...
They only had noticed, because they had a Linux PC, and the commands "typed" by the mouse were
aimed at Windows PCs.
From the security point of view, having office PCs without USB certainly makes sense...
Even without USB, note that PS/2 is bidirectional, and your PS/2 keyboard can type anything it likes. It could also possibly type in some code which then exfiltrates information. If the keyboard or mouse had smarts inside and a wifi chip it could even exfiltrate directly, to a vehicle parked outside...
Having said which, Windows can in a corporate environment be very much locked down, as to which programs it will run. The rogue keyboard or mouse might need to compromise an application somehow.
Hmm.. there certainly is a market for transparent keyboards. Not as a glass keyboard, but without too much logic inside, so that one can see that it doesn't do things its not supposed to do.
Well, maybe one made of glass would be cooler..
