It is currently Mon Sep 30, 2024 5:29 am
 Post subject: SPI MISO Mixed Voltage
PostPosted: Mon Aug 07, 2017 4:35 pm
Just want to double check something with y'all.
Namely, I've got an SPI MISO line going into VIA input pin PB7, which is connected to two SPI devices. One device is 5V, the other 3.3V. The VIA (and most of the system) are on 5V.
My concerns are twofold:
1. According to the VIA datasheet, to be recognised as a logic high the signal must be Vdd X 0.8... 5V x 0.8 = 4V which is 0.7V too high for 3.3V. Now, I believe that that the VIA datasheet is conservative in many of its numbers, and -normally- CMOS inputs can cope with logic highs as low as 2.7V with Vdd=5V, so I suspect that actually it'll work with 3.3V=High fine, but I want to see if anyone has any experience? If it won't, then I need to translate the 3.3V up to 5V.
2. When the 5V device is selected, the 3.3V device will tristate its MISO pin. I'm therefore believe that the 5V won't get into the 3.3V device and blow up its internals, but again I'm not certain. Unfortunately the datasheet for the 3.3V device does not specify if it is 5V tolerant when tristated.
PostPosted: Mon Aug 07, 2017 4:55 pm
It would help if you specify the devices so everybody can take a look at the datasheets.
1. 80% Vdd seems quite high. I have used 8 bit AVRs at 5V specified to have a high threshold at 40 - 60% Vcc with 3.3V logic levels and that worked.
2. A 3.3V device is only 5V tolerant when the upper clamp diode of an input pin is omitted. Otherwise you are charging 5V through the diode into the 3.3V power rail! You should be able to detect the diode with a DVM (Pin -->|-- Vdd).
PostPosted: Mon Aug 07, 2017 5:03 pm
VIA: W65C22S
5V Device: FM25W256
3.3V Device: NHD-2.7-12864UMY3 (specifically the MF_SO pin)
PostPosted: Mon Aug 07, 2017 5:25 pm
It's not guaranteed to work. I would remedy that with a section of a 74HCT125 tri-state buffer. Mouser thru-hole choices are shown here, and data sheet at http://www.ti.com/lit/gpn/sn74hct125 .
PostPosted: Mon Aug 07, 2017 6:47 pm
You probably noticed that you can run the SPI-RAM also at 3.3V, but that is not helpfull if you need to run the W65C22S at 5V. The display is definitely not 5V tolerant. I would recommend a proper logic converter like below.
PostPosted: Mon Aug 07, 2017 8:14 pm
Yea, I had a feeling that the screen wouldn't cope with 5V, even when tristated. Nevermind, I just won't use the Font ROM. I didn't really need it anyway, it just seemed a shame not to hook it up since it was there.
Users browsing this forum: Google [Bot] and 8 guests
