cbmeeks wrote:
I've ordered all new electrolytic capacitors for my PET 8032. I'm going to recap the digital PCB when they come in (I'm not going to recap the analog board to the CRT at the moment).
The one capacitor I haven't ordered yet is that gigantic screw terminal cap that connects between the transformer and the PCB. I don't have it in front of me at the moment but according to the schematic I found online, it's 23,000 uF. It's the size of a small flashlight (lol). Anyway, I looked up a similar cap (guessing around 25V) on Mouser and they range from $23 to almost $60 for one. Yikes.
I already spent $30 on the other caps (with a few extras) as I prefer to buy Panasonic or Nichicon caps.
So, my question is, how risky is it leaving that giant cap where it sits and just using it (assuming it still works)? Keep in mind I don't plan on using my PET very much. As I just want to clean it up a bit and use it for a few days. It will live most of its life in a climate controlled basement.
If it were to leak, I could see it destroying the metal case it sits on but the PCB is elevated slightly. Unless it were to explode, I think the PCB would be safe.
What are your suggestions?
Thanks
Many of the old screw type caps are of the Mallory CGS or Sprague 36DX types (other brands have their own similar series). In general these are very long life caps and intended for commercial grade power supplies. I've never seen one with a bulging case, mainly because they have a vent plug on the terminal mounting disc. I have seen them go open, short and spew out electrolyte from the vent plug before. It would be a good idea to get the full spec from the cap first. They do have common case sizes which specify the case dimensions and mounting distance. And yes... they are expensive these days.
As it is a screw type, you can likely remove it without much difficulty and test it for leakage. If you have a higher function DMM (that handles capacitance) you can check for capacity as well. If it checks out okay and the vent plug looks clean, it's probably fine.
